Knick
December 5, 2022, 12:09am
2
Here I found these in the search bar above left magnifying glass.
There are more if you look. you need to give more info so people can help you.
Start with table type, Plasma cutter, etc, has your table been working fine?, have you had this problem in the past? have you made any changes just before having this problem?
Make sure you come back and tell us what fixed your problem please
Thank you in advance. I’m getting the error Cutting Voltage Lost during cut. I have the Pro with THC with a Hypertherm 45xp.
This is just a simple test piece and I can’t get it to work. The arc stops at the same point every time and says it lost Cutting Voltage. I’ve checked the clamp and tried in several places. I’ve adjusted the cutting height from the Hypertherm recommended .06 in increments down to .03
[20220815_150404]
[20220815_151618]
. I’ve changed the pierce delay in incremen…
Hello all,
New to the forum, I have a crossfire Pro with the razorweld cut 45 with THC.
I have had the machine up and running and cutting for about 6 months now and made plenty of cuts. Last week I was cutting .25in and I kept having and issues where it would start to pierce the work piece and the arc would go out or during a cut the arc would go out and give me the message “Cutting voltage lost during cut”. I was using all the same cut parameters that I normally use on .25in, .06 cut height, …
I keep having the same issue and have not been able to correct the problem. No matter what I try the same thing happens. I can usually get about half way through the cutting process when the torch stops firing and the program pauses. Any ideas would be greatly appreciated.
I am running a HTP MicroCut 875SC v2 plasma.
[Voltage lost]
