when I simulate the tool path in f360, the order of the cuts is backwards. it simulates the outside cut before the inside cuts. Why would that be?
Probably best to post your F3D file here, without that we are just guessing.
Did you extrude the part and select the body when generating the tool paths or did you select each path individually?
If you selected them individually did you select preserve order?
how do i upload a file to this reply?
use this button when you hit reply…that is the upload function
i did that and i cannot find the file. i searched by name and its not coming up
I do not know Fusion at all…I will tag @TinWhisperer …he is a confusion360 master
what do you use?
inscape and sheetcam…and sometimes AUTOCAD…
yes, TinWhisperer will be able to help, thanks
BTW its happening in all of my designs
@72Pony is on the right path
In the 2D profile menu did you individually select all the geometry? Or did you select the geometry from a body by clicking one face in the manufacturing environment?
When selecting by line by line or contour by contour sometimes The preserve order function can get engaged, this may cause of your issue.
Post your f3d and we can take a closer look
i tried to but can’t find the file on my computer to upload it. i can only see it in f360
You can export a file here
make sure you are saving as a F3D
The important note is that these 3 dots … in the small orange box will bring you to the file you are saving to.
and you may select a different location to save as well.
widget v1.f3d (122.2 KB)
it cuts the outside last is all of my files
yea, why is that
