I thought you might want this. That went all wrong. Ok so how do you attach a SVG here?
Not sure, but would like it, you got a dxf of it?
No ,SVG is all i have, I highjacked the image and converted it. Shh dont tell anyone. I will get it to you when i figure out what im doing wrong.
I thought they had changed the forum settings to allow it but if not, just change the name from xxxx.svg to xxxx.svg.dxf and tell whoever downloads it to strip the .dxf off and you’ll be fine.
I started listening at xxxx.
Glad to see you’re up and running in the goat shack. How is your desiccant system holding up? I blew through desiccant by forgetting to turn on my dryer. I definitely needed the dryer.
And @ctgolfer I have no room for a giant manifold. Don’t post your picture. Lol.
Thanks James I forgot about the ole change the name trick. I emailed it to him.
Seemed like a good sign for his converted goat shack.Cute sign. Looks like a little thickening of the legs and tail joint might be helpful to keep them from bending.
So its been a hectic couple weeks, thanks for all the support.
I haven’t had any real issues until Wednesday night, basically have been cutting something every night after work, signs, bottle openers garden signs etc.
Every cuttime since I got it running, I do same routine…until Wednesday night
Tuesday night I cut out a 11 x 36 in tree frog group for buddies garden, powered down as usual.
Wednesday night, I fired it up…moved torch out of the way(jogged all axis) put new 48 x 48 sheet on to cut out a 24 x 36 sea turtle for wifes office, I programed sheet cam to start in the middle and skip around some for heat warpage and slug removal.
Set x/y zero, dbl checked everything…cycle start.
Moved to center of part THC did its thing and…1-1/2 cut and low arc voltage alarm! Checked ground yup attached, tried again…same thing.
Crap, shut it down pissed and beaten.
Thursday night fired up as usual, swapped metal out and tried my f bomb. Tap file that has worked awesome.
.nada same shiat…
Today went out with fresh
Tap files, I did this morning .
computer fired right up BUT fire control wouldn’t open, task manager shows it starting but stops at a random 25 to 69 kbs.
Uninstalled, reinstalled twice.
Once from computer and once from fresh download off thumb drive.
It is now saying W7 is not genuine…arghh…I have thev damn disc and sticker still…wouldn’t run after repair, so I am reinstalling windows…again
Just venting
.%@#%×!+ Bill Gates
Back to shed…
Sounds like a few things are going on. Seems weird if it ends up being a windows issue.
Well, I brought computer into house again, am now 9:25 est…doing a reinstall.
Installed firecontrol on 2 other computers this morning, no issues at all.
So, my old computer is not working as of an hour ago…let us see what happens this morning…
Browsing Amazon for replacement…may go mini v/s lap top
My PC dropped dead on Thursday morning. Got a new HP tower at Walmart. Now in cloud recovery mode, this will still take a few more days to get all my (474,996) files back. Its no fun when this happens.
At least you got it figured out!
Being able to bring the laptop into the house to work on stuff was a must for me. I didn’t want to have to boot my Mac into windows every time I ran a tool path. I just can’t stand windows. I used to love HPs but the first laptop I got to run the table was a pile of crap. Just felt cheap. Spent another $150 on a dell touchscreen and am much happier.
If I only ran windows though, I’d be tempted to do a mini pc to keep in the garage and only run fire control.
Well dug out an old laptop running W7 and installed FC yesterday evening and appears all is well, tonight I will move it to table and try it.
Interesting note:
I called Microsoft for shits and giggles, told lady I have disc and original box with sticker and have reloaded it twice and still says not genuine and it is old.
I was told my validation code is expired? WTF? SHE SAID ITS JUST TOO OLD
So hopefully this lap top will work for right now.
Also to note, I found this here…dugh and will try it also
Let ya’ll now tonight and see if the above fixes it or if it is windows not letting it open
Hectic again. Good news, had this issue about losing arc etc…thought it was computer…nope.
Now FC not opening was…
So I posted this last night or this morning
losing arc
And new cable on the way, and with a small wt holding cable down so I saw 0.0V at idle I made all of these
They are not laser engraving or inlays, it will be wall or desk art. We’ll see. Small guys are 1/8 inch scrap and big guy is 14 gage…
How’s the space working out splash/cleanliness wise? I’m operating with a similar space - 78" wide and just tall enough to clear the cable boom.
Cleanliness? Lololol under my table now is:
1 mig welder, 1 tig welder, 2 tots of crap and I now have a bunch of scrap pcs of steel supported by all the walls
Splash wise its okay, I have a few pcs of aluminum I slide down into water pan in front of material and that helps as a small retaining wall
I am loving it so far, I do have to wear a mask and ear protection.
And need to clean up in thete. I have been making stuff and still have assembly boxes laying around
You are 100% moar organized than me
By the way…not fair. You have room outside the little cube.
I have a suspicious lack of goats though! Thanks for the quick reply, I’m going to have stuff stored under the table too, so I guess that’ll just be how it is for now
I installed FRP sheets on the wall so they are easier to wipe down, but someone raised the concern about how dirty everything is going to get almost immediately. I think if I have some splash guards around the nozzle it will be manageable, and I don’t expect it to be perfect anyway. It’s meant to be used!
