Great cuts!! but .111" hot rolled? it seems more 11 gauge than 14. or am i missing something?
Could be 12ga - or 11ga - thatās in in 0.111" range.
Yea, ordered 14 Ga. sheet.
But it was thicker then the typical 14Ga. Range
I always measure anyway with a micrometer every sheet
So I can get my cut set right on my machine.
Ran 5 test cuts on .105ā cold rolled steel for a project I have to do.
.070ā torch height
.9 Pierce Delay
.8mm Nozzle
30 Amps
Water table
Pick your poison!!
All cut really Good!
50 ipm is only one that had visible dross on the back. Rest weāre nearly dross free.
None had any dross on the front at all!
All the cuts were straight with no bevel and super clean!
Only real difference was the finished cut Kerf width.
See photos.
Looks to me like 70 ipm is maybe the winner
Why? Because there was almost no dross and the kerf width was only 0.031ā & a perfect cut through with nearly non existent bevel.
Although any would be acceptable for what I do.![]()
0.105ā cold rolled
.8mm nozzle
30A
0.074ā torch H Clearance
Water table
70 ipm
.8 pierce delay
Clean straight cuts
No noticeable bevel
No dross on front
Barely any heat effected area ANYWHERE
Little to none dross on the back
Cleaned off in about 3-5 minutes
RAZORCUT45
These posts you are doing are incredibly helpful to the community at large, thanks for taking the time to share them!
No problem!
Iāve
gotten just as much as Im giving.
This moose seen is for my Wife and the Master-bedroom Wall .
So it needs to be
perfect. LOL
Iāll keep posting my test result as I move into differ thicknesses of sheetā¦
Another sheet thickness test cut::
.120ā cold rolled steel
.070 TH
35A
1.0 sec Pierce delay
.8 mm nozzle
Input air on RAZORCUT45 Gauge is 70psi
No dross to speak of on front or back!
Looks to me like 70 ipm was the winner with a .040ā measured KERF WIDTHā¦
Cut quality is very good with barely any bevel!
WINNER for me was 70 ipm
Although none were all that bad.
So I still make my own, no choice but to test cut all material first and note my own settings.
That give me the best cut results
I just made a cut with my results on my post above on .120ā cold rolled, and it came out perfect, just as my test cut showed at 70 ipm
Itās the only way to dial it in for max result,
Woohoo. Iāll update the online spreadsheet with these values. Only took us a year to get this far
Did they give a torch height? Or did I miss it in the picture, it is late so itās possible I missed it
So, while the cut chart is a great aid to folks like me, Iāve yet to figure out why the pierce delay is listed at 0.01, 0.02, etc. But it actually needs to be 1 second.
PD Is what ever you need it to be.
1.0 sec is way too long on 16 18 20 22 gauge
14 12 11 10 8 Etc could most likely use 1.0 or longer to get through.
If I cut on the line, I have PD @ 0
So I donāt get a round burn hole and the line in clean
Which cut chart are you referring too?
The one from RAZORWELD. (Which isnāt much use as the ipm speeds are not compatible with the crossfire)
Or the one we started on our own in the forum?
Theyāre not? Why is that? Iāve found my IPM speed settings different too, but I just thought it was my cheapo Plasma cutter.
The Google docs one from the forum.
All these cutting charts are made in a lab with a $30K or more setup, not a crossfire and a back room of a garage.
iāve looked through all 37 posts, canāt find the link to the Google Docs cut chart? can someone please post the direct link?
Same - It looks like there was one at some point but the page no longer exists.
A little help?
I finally found the link (Razorweld Cut Chart), but honestly, the chart was not easy to use, and I didnāt want to risk wasting a $100 steel sheet trying to figure it out. I ended up using the cut chart provided by Razorweld and posted by MO-Hacker, specifically for this cutter. (Razorcut 45 cut chart) Our max ipm is 300, but I cut mostly 10ga Mild Steel anyway. By using Razorweldās chart for āoptimum travel speedā (0.50pd)(98ipm), I get perfect cuts every time. Which is awesome, because the basic settings provided by Langmuireās tutorial videos made terrible cuts, and half the time didnāt even pierce.
Edit: Iām actually having some trouble with my pierce delay today, but other than that, everything is perfect using Razorweldās chart.
