Hypertherm Powermax 45XP without CPC Port Wiring Question
I have a Hypertherm 45XP without cpc port. I currently have it wired for my torch control for my OG XL Crossfire. When I bought my new Crossfire Pro Table I ordered the THC and the cables for connecting to the table. Cable listed below:
My Question is does anyone know the cpc port I need to order that I wire into my Plasma Cutter?
Thanks in advance for any help.
Since your machine does not have a cpc port factory installed you have two options.
  1. Install a cpc port on for 45XP and use the cables you bought to hook to the LS-THC
    this thread has some details and links
langmuir forum hypertherm-45xp-upgrade-question
Service Manual Page 108 - 110
  1. Install Raw voltage pigtails and use that method to the LS-THC and do not use the cables you bought.
scroll down to 4: PLASMA CUTTER WITHOUT CNC PORT (RAW VOLTAGE)
Thank you. I want to install the cpc port, but I can’t find the part number.
Hypertherm Upgrade Kit - CPC Port w/ Selectable Voltage Ratio - 428653
I believe this is what you are looking for but please double check with the seller.
Search “kit 428653” in google and there are quite a few vendors
This is your support page for the Hypertherm 45XP
45XP Support Page
there is an exhausting amount of material about your machine.
Here is a link to the install manual for kit 428653
CPC 428653 install manual
Thank you so much! :pray:t3:
If you do end up choosing to go to the raw voltage route.
This PDF shows the factory locations where that voltage is taken from
45xp raw voltage terminals
It looks like your question was answered, I just wanted to also put a quick reminder here that Hypertherm CPC ports will only function if you use a machine torch. If you use a hand torch, the CPC port will lock out.
Also, the voltage divider of this CPC port will have a selectable ratio. Be sure to set the voltage divider to 50:1 when using the LS-THC
Thank you!
Thank you for all your help. I really appreciate it.
