The arc voltage lost error is NOT the same result when interference is at play. Interference causes your laptop and/or FireControl to freeze up. If a Arc Voltage Lost error was shown to you, then FireControl isn’t frozen.
Is your THC working properly? When its cutting are you getting a healthy voltage displayed? The arc voltage lost error pops when the voltage is less than 10 volts during a cut. Theres only two ways that can happen. One is you have actually lost arc voltage (or didnt establish it in the first place if a misfire occured), or your THC is not sensing the voltage properly.
Interesting, when I emailed support, they said it was interference that was causing the problem…
“We’re going to send you an additional two ferrite chokes to connect to your USB cable. While you are waiting for that, can you try to do some cutting with THC disabled in FireControl to see if it still freezes?”
Before it didn’t seem to make a difference. However with the mod in place now, when I turn THC off, it does appear to be cutting… Suggestions?
Of note, I see that I have 2 blinking yellow LEDs on the board now… ‘TX’ and ‘RX’. Does that help with troubleshooting?
Also, how do I check if I have healthy voltage? I don’t see it showing up on FireControl. I have ‘Nominal’ set to ‘Smart’ and the Live voltage box (red box) never has anything in it…
If you are using a Razorweld Cut 45 check your retaining cap. It shouldnt be too tight. When too tight it causes arc loss. Also make sure the connections are kept clean on the cap ring and the 2 pins in the torch
Ok so sounds like you had interference and that is now fixed by this mod (since you can cut now with THC off).
If you aren’t getting arc voltage displayed in FireControl, it could be that something isn’t connected properly. Follow this troubleshooting guide to help determine where the issue could be: THC Arc Voltage Troubleshooting Guide
Can confirm, mod works for me too. It will still sometimes stop firing in the middle of a cut but the table will still move and it doesn’t freeze up FireControl
Yeah, what cutter? If it’s the RW, I had the same experience. Turned out to be an issue with the internal air reg even though everything pointed at EMI and arc faults. My air was set at 70 and dropped to 60 during cuts, causing arc loss errors as it shut off the arc. Solution was to crank it up to 82. It only dropped 2psi to 80 after that and cut like a champ.
As promised. Here’s the video. I hope it takes a little of the mystery and scariness out of the process. It really isn’t that hard or possible to screw up.
The video from Mancrafting is very helpful. For those who have thought about trying this without dismounting the board, I just did and it was no problem. The sequence was remove cover screws, unplug four connectors, pry inductor loose with long needlenose pliers and dab on solder. The hardest part was getting my 55 yo eyes to even see the danged L1 label. I attached some images in case someone wants to follow along. They are: (1) & (2) the four plugs you will disconnect for access in their correct orientation; (3) the view of the inside with the wires tucked out of the way; L1 is near middle on the right side ; (4) an image of the pliers that worked (third pair I tried) and (5) a closer view of L1 inductor removed. I suggest starting your bridge on the top, so that gravity works for you.
I was thinking the same thing, it could be done with the board in and just unplugging the harnesses. I took mine out just to get a better position to solder. I don’t think it made a difference for me.
Only my second time soldering, but apparently my deep TIG incompetence prepared me well for a process that requires touching filler to heat source. At least for a rightie, access is really pretty clear.
So far, it jogged great so I didn’t lose continuity or anything like that. I have a really noisy cutter and plan to test with it right under the table tonight or tomorrow night.
Just completed this tonight. I have a heavy Cutting weekend planned, I’ll report back . Hypertherm 45 sitting 12” away. I’ve had a couple strange things happen previously on start up while jogging the machine. We shall see if this was the cause.
