you can select a line of code to start from if you like.
Feels like an air issue.
Its like my software stops working. I cant press the pause or stop on the program and reset with out shutting it down and disconnecting it.
is it a laptop? is it plugged in?
right now its sitting still and the run button is flashing on and off like its still going.
Mine does that if I bump the USB and it loses connection for a second.
I’m going to be on the road here for a bit so I won’t be able to reply for a while.
Hopefully someone else can jump in here and keep going with you.
it’s a signal loss issue I believe.
Either by the USB physically getting disconnected for a second
Or
Potentially electromagnetic interference corrupting the signal.
i was using a none system usb with extintion. used provided usb and got a good complete cut. thank you. now, what am i doing wrong in my programming?
I’m going to review that file you sent some more and try to pin down what’s wrong with that verifying.
The only major change I made was went back to the sketch turned it into a body by extruding it and then developed CAM from there.
I’m going to try to open that original file you sent on my fire control next time I’m at the shop.
i tried your original program in firecontrol and it loads fine.
1001 Eagle 1.nc (92.8 KB)
I believe your eariler validation issues were also because of the USB extender.
Try to load it again on your machine.
Thank you for your help.
Hey TinWhisperer, hope you can help, long story short > been using the pro for 2 years (its been good) but hadn’t used it for 4 months, use a substription of 360, it was on auto update so it updated itself to the new NC Program for Machine and Post, also in this time of not using the Pro my PC died and was replaced with a new one running Win 11, anyway,… I have tried to get it all up and going again, have watched your vid (with you talking) of setting the Post Programing (well done) could yuo give me a link to it as I can not find it now, I am struggling with getting the Machine part of this NC Program settings right, Did you do a vid of the Machine programing like you did for the Post ??
I did this video with no sound awhile ago . Is this the video you are thinking of?
I still have not upgraded to windows 11
Thanks for the reply, the one I was looking to watch again has you talking, not to sure what I have wrong now, can I send you screen shots /
These are the only two videos I have where I’m talking in them currently.
I am working on more.
Post some screenshots of your problem. It will help me or somebody else figure out a solution.
http://langmuirsystems.com/software/fusion#post-section
May these explain it better?
I have another issue if you dont mind. I ran my unit 2 days ago cutting 4 different files. Today i went to run another file, and got an error on pierce delay.
I havent changed anything in the programs
Did it fire at all?
Sometimes if you recently changed your consumables it might have a lockout on the Plasma machine.
Maybe you grounded on the frame or slats instead of the work. I think you’re delay was set at .4 so about as short as you can get, so something like this might make a difference.
Plasma Machine may be locked out from some other error.
Finnaly got it to fire thanks. So I do have another question. I have a spinner im trying to G-Code and the first time i ran it, it cut everything. Unfortunatly it cut out too much. While cutting out the wing, it cut out the line of all circles and ovals and cut inside of the wings. I tried going back and redoing it. For some reasone, I can not get the cut inside of all of my ovals and circles. Only some of them simulate cut. Is there a better way?
How did you resolve that misfire from the last post?
It’s likely that Fusion believes that the combination of your lead in, lead in radius, Pierce clearance, kerf width, lead out lead, out radius it’s too big to fit inside those little openings.
Redeuce your pierce clearance to zero maybe.
Well i lost the belt on my big compressor and was using a 30gal temp. So I guess it didint like the pressure. Got the big compressor up and running and no issue othe then the the pierce. Ill give that a try thanks. How about the tips? Is there a better tip for small cuts?
