Never having modified G code, is it safe to assume F is my travel speed?
Which line of that code should I change exactly?
Again I’m happy to set my phone next to my torch and record a video.
As for material flex no sorry, I’m using 1/4" plate as I want a solid, flat surface for accurate measurements. But if say the material was 20 gauge, in theory it would flex the material as the Z axis pushes into the material for a little bit before it springs back up.
Yes f is feed. The line may or should say cut height. Probably f 100 that is 100 ipm. As long as you change that should not hurt anything. As far as a video I am at work cell signal is bad . Someone else I am sure will chime in on it though. Be sure to video the his switch
Yeah but I don’t think Langmuir would cover this; I could try and ask.
I first experienced the issue when I first purchased my table. I had an issue with Z axis as the instructions or the site stated they’re tightened from the factory.
Real life experience told me otherwise; multiple posts on this forum and the Facebook group experienced the same.
But they stripped immediately when I tightened them (yes I used the correct metric 2mm allen, I own many SAE and metric tools).
Disassembly wouldn’t bother me, I just want to maintain the remainder of my warranty period and have it taken care of if they can/will. If they say no, even though I have an email from them acknowledging the stripped screws from January 17th of this year, then I’ll take pictures of disassembly.
Looks super easy, just don’t want to void my warranty if it’s covered.
I could be wrong. Ls seems pretty easy going about stuff. Some have heavily modified systems. A call email or something will confirm… sometime that takes time.
