I am getting chatter on my X axis lead screw when jogging to the far positive position (upper right corner of table). I have tightened the screw at the end so there is no slop between the screw, washer and bearing as others have recommended. I have also used three in one lubricator. Still having issues. What’s next to work towards resolution?
I get the same or similar behavior but I can confirm that the machine screw that secures the lead screw to the bearing is thoroughly seated. This chatter occurs only along ~10 inches of x axis travel within ~ 18 inches of the right y axis rail.
It doesn’t need to be centered it it should not be touching the bracket. Try loosening the nuts and run it along the length of the screw. Tighten it down where it’s not contacting the screw & bracket.
Sort of. If you line up the black rectangular mounting block with the steel mounting plate the screw may not settle in the center of the flange hole. It’s been true of the Crossfire since the original. Langmuir has said it’s okay if it’s off-center as long as the screw doesn’t hit the sides of the flange hole in its travel. It can be off-center because of the flex of the screw or small deviations in the installation of all of the mounting blocks and rails.
Did you install the correct motor and lead screw bearing mounts to the X gantry tube? I accidently installed the Y bearing mount to the X gantry tube and when i jogged it to end toward the bearing mount, it would bind and stop about 1 inch from the end. Found out i installed the wrong bearing mount. I swapped both mounts and worked fine without binding.
My lead screw bearing mounts are in the right spots short one being on the x-axis y-axis have longer ones. Motors are installed correctly as far as I know
It has a really hard time going in the far right x axis. it will go but it slows down hesitates and that’s where it makes most of the chatter right before it slows down
ok thats what mine did. recheck the motor mounts and the bearing mounts on both axis lengthwise. one is probably shorter than the other which means you got the Y mount installed of the X .
ok, it could also be that black bracket that the lead screw goes thru in your pic above my not be square. loosen that up a bit so it “floats” and jog it back and forth to see if it helps any.
