Okay…this 4 days of of 10 to 12 degrees has airlines frozen so can’t test anything today, I should have heat tape on Monday.
I was going to see what happened with 50 divider and torch trigger undo from plasma.
I took this 15 min ago…note frozen water…it went from 60* to 10* over night…oops
That must be one of those plasmadyn torch’s. Undo the back nut, then remove the little cover, find the wire going to #3 or #6 and pull it out of the back of the hole, fold it back out of the way, put cover back on and back nut. That will disable the trigger wiring.
So I disconnected #3 the yellow wire, #6 is black wire. Nothing …(wire was thin like 18ga assume trigger wire)…program ran until it figured out no arc and stopped with no arc alarm.
Disconnected #1 red Wire(maybe 14/12ga) , other is #9
And hit start, arc fired and continued to fire until zI unplugged it…pita…
So right now all 4 wires plugged in, I’m cold…need bourbon and a fire…
The pilot arc wire is split and goes to #1 and #9. If you are cold with the #3 and #6 wires plugged in then they are not hooked to the torch head or the cup pins are not making contact.
Holy sheet me and wifey have been really snotty and coughing last 2 days…well I woke up with 102.3 temp, aches ,congestion etc…shit. we take care of her 80 yr mom daily, so we went to get tested for the kung-flu…get this, you listening? We couldn’t get instant test…because…ready? We have too many *%$@& symptoms…FML. so we did self test and nda to kommiefornia.
Now apparently wife found a place an hr away, to get instant (false whatever done) the family is freaking out because waaawaaaa other members need to help her…
If my temp drops, I will be in the goat shed, I got heat tape for radiator and need to make some calls either today or tomorrow.
George again thank you, I have something to check out
I feel you need a smoked pork butt and a drink to clean up that congestion. Maybe a soak in some hot water. Wait thats normal dailie life… All jokes aside I hope you get better soon. The wife just got over the commie flu. She said its not all that fun.
Wow, glad to be back the last 4 days sick sucked and then new years stuff.
So disconnected yellow wire and trouble still once again. So I noticed the V on thc was +/-3.5
Used to be 1.5…said okay and turned thc off, guess what? It cut and finished the small pc.
So I just ordered a new dmm since I couldn’t find my other 3 or 4 and will diagnos thc, next week.
I will update other thread also, didn’t realize I had 2 going one, needless to say…there are 2 models of cnc ports on the razorweld 45, ONE IS 2 two prong, and then mine has a 4 prong and a 2 prong, if you have the 4 prong plug turned 90* trigger won’t be triggered…
On to thc checking, since it worked fine for 6 months…
Stay tuned to adventures from the goat shed…and no, smart–'z this will not have a brazzer logo
Lol…cereal? Goats are electric proof, asshats would chew through 120v like nothing… I never had power out of the shed…until…they got disappeared by…the ones I can not mention, due to divorce and family lawyers
