In this stream I will use a customer provide paper template to create a CAD file for this part.
A quick video going over some of the section process and how the selection acts different depending on how you use it .
Thanks for doing this! I had no idea there were so many selection options available in those drop-down menus. Being able to turn off or select only bodies ect. is awesome!
you are welcomeAnd remember the Escape button it is the most underrated and most important button in fusion 360.
If you look at my keystrokes down below there’s probably no other button I hit more maybe shift.
I have been using the Tecknet mouse and apparently they are not supporting it with remapping of the button functions. (Plus I got a nag message from Microsoft that said my system is no longer meeting the minimum requirements for running Windows 11…so maybe I have bigger problems).
Anywho, I found a great software for free that “went where others dare not tread” and allowed me to remap one of my side buttons for [ESC]. (Whining from me: That is just a long reach up there to that key. You ‘bots’ have those lightening fast movements and inhuman reach capabilities.) There are a number of those helper programs out there but this one worked wonderfully.
I ll have to look it up. I thought about buying a 3d connexion package but it has not happened yet.
This is my current mouse and keyboard.
https://www.razer.com/ca-en/gaming-keyboards/Razer-BlackWidow-V3/RZ03-03541900-R3M1
I really like using a mechanical keyboard instead of a membrane keyboard.
This razer stuff seem to come on a big “sale” every 6 months for 30-50% off , keep a eye out for that if you are in the market.
I bought this desktop in 2020 and get the same warning. As long as it is updating to the newest version of window 10 you will still be ok using Fusion 360 for the foreseeable future .
Great find on the software. I use a piece of software called antimirco for key mapping my SNES controller for use with FireControl.
now while searching for this link it look like a new version has been released. Antimirco X so something to check out if the og stops working for me.
I keep my left hand on the left side of the keyboard While CAD ing so all the hotkeys and key combos are right there. I have put the time in to become fast. I’ve been slipping some over that last couple months while ive been studying other thing but by the end of next week ill be done that quest and back to more CAD.
some recent twitch links
simple drawing to cam workflow with a evil Santa character
evil santa v1.f3d (1.4 MB)
Wind Spinner CAM
hum spin v4.f3d (2.4 MB)
Selection Tool
I can see that I am going to need to get a lot better with my management style with components to be able to do something like that.
My style is more like finger painting: splash a body here, a component there.
Edit: You know a lot of us say “We don’t need 3D designing capability since our machine only cuts in 2D.”
I understand the implied meaning of the words and it simplifies the learning model when you are just starting with plasma CNC cutting. But many of our parts are interacting with a 3D world unless it is a flat plate hanging on the wall.
I made three different Rocket stoves from design to cutting but the part that I was always guessing with was how the crisscross pot holder structure would be sized with slots to fit on the top of the stove. With the 3D design, I actually assembled 3D model in the virtual world of Fusion 360, mated my proposed component and saw how it needed modification. By altering the component, I got the perfectly designed part. The first trial cut fit like a glove.
I did give some allowances but I did with the two other stoves, as well. The big issue with the first two stoves was that they did not fit without using a hand grinder to widen the slots. With the 3D design, there was zero fitting needed. It slid right on without as much as 1 mm of movement.
Doing a quick walkthrough for a fellow on the Autodesk Fusion360 Forum. I thought i d post it here too.
Re: 2D empty toolpath - Autodesk Community - Fusion 360
I’ll Start in about 10 minutes
oh no i accidently had my mic muted…
autodesk forum exampl 1 v1_.f3d (1.5 MB)
The embedded twitch videos seem to be down again ,here is a link
https://www.twitch.tv/videos/1851015208
Here I thought it was a Twitch issue that I was not registered. Just Techno music playing. Darnit!
https://www.twitch.tv/videos/1851871789
Trying again with sound.
Here is the file the goes along with the video . the screen are the same as my last post
Example Forum autodesk 2 v2.f3d (1.5 MB)
Starting a stream in 20mins
Looking at a couple projects but mostly testing if the double live stream to both YouTube and Twitch
One of projects is one of there kids sandbox diggers
I have a lettering set I want to draft and cut for a customer. I’ll be live streaming the CAD CAM workflow in about 15 minutes
Live Stream Channels
Langmuir Forum CAD of flange from pictures. No talking just music. Quick morning stream starting shortly
inside of one and outside of another.
They managed to cut those flanges between some chores. Thin, only 14ga ss
I used hypertherm fine cut consumables, low speed, book settings. No clean in these pictures
There about three and a half by two and a half in size the holes are 5/32 (at least that’s what I drew them I’ll have to check what they’re actually at)
@TinWhisperer
I’m setting up to cut some 16ga stainless and bumped my pierce delay to 0.6. I did my test cut and checked my 1x1 with few other things and everything looked fine. It seems I’m always adding 0.1 or 0.2 over book for pierce delay. What are your thoughts on this?
