Ok I think its simple but I just want to be sure. I just ordered a machine torch for my Razorweld Cut 45. I have the newer version with the ports on it and the x45 torch. To install the machine torch I just simply remove the torch on/off port cable and install machine torch correct?
you should just have to swap torches… everything else stays the same.
Make sure it’s not one of the auto firing ones. @GunTruck1776
What does that mean?
