I’ve got 32106060312, CNC port is in the lower right, ordered 8/18/21.
Thank you @ksanislo and @wsidr1 I have updated the list with the information you have provided.
@ksanislo can you please confirm the location of the CNC port on your unit.
That’s correct, mine is lower right when viewed from the rear. I’ll hopefully be able to give it a solid testing with the table this weekend and then can report if my unit has troubles or not.
That is very bizarre considering it is the next generation of case and not CNC Port should be in the top right?
Being that’s the first generation of the New Port location I wonder if they reworked some chassis from the last generation of the old Port location into the first run ? That blue line in the chart should be the dividing line between old and new equipment. It’s very curious that you’re chassis has that Port where it does.
It would be great to get the port location on those other 2 June built units.
@ScottNH I went back through this topic just now and RHL port location was mentioned and I had miss it.
@72Pony did you end up getting a Primeweld?
@mickkell where is the port location on your machine?
I have add a new column to the chart to track weather it is hooked up divided or raw voltage.
Looks like the CNC port location change did not go into production until after 060621. Mine is 2 months newer and has it in the upper right. Interesting.
Lower right / raw no problems
Well I Have a cut 60 with it on the lower right side, My Table will be here Tuesday so I will know in a week after that. I spoke to Gene at Primeweld and he said it should work fine. So we will see. Also ordered from Plasmadyn a 25’ machine torch for the cut 60 with the X45 head. So I can use the fine cut From Hypertherm if need be. serial number 32106060117
I did get a PrimeWeld. I am out of town for the weekend . I will get you the info when I get back.
I hooked mine up to raw voltage after calling Primeweld to confirm no warranty impact. Works fine.
The guy at PWeld seemed a bit miffed, and basically said ‘it’s only been like one or two units have problems through the CNC port when paired with a Langmuir, but do whatever you want. It wont’t affect the warranty’.
I think he was more irritated Langmuir had just taken Cut60 off the approved list, and I caught a little of the frustration. They pulled it after I had ordered, but before I received all my deliveries, so I was a bit miffed myself, so I know how he felt.
Here’s the statement they made when they pulled the Primeweld from their compatibility list.
I can imagine even with primeweld not being on the compatibility list and being on it for a short period of time they sold many many extra units that they would not have sold if it wasn’t for langmuir systems.
But frustrating for everyone. I’m sure langmuir would love to have them back on the compatibility list. And it seems some of these newer serial numbers are proving very reliable with the divided voltage port so maybe we’ll see it back on the list soon for all units after a certain serial number.
@langmuirsystems any chance in the future Primeweld might make its way back onto the list?
32107500424
CNC port on lower right
Purchased early November 2021
Sept 2020, Cnc port lower right ,Raw voltage through the Cnc port , no issues.
@72Pony @T00LONGATIT @Wsidr1 @greysonvalleyRR @MechanicJon
Thank you I have updated the list with the information you have provided.
I believe you are right . after 2021 july 05 sometime full production of the reworked unit.
can you double check this. I think it should be 32107050424 ?
If you want to be added to this list please post your information.
I have added I new column to track which torch people are running with there set up
You know I was driving myself crazy thinking I was getting that wrong somehow looking through your spreadsheet. The 50 under the day column doesn’t make any sense. I probably checked it 10 times before I hit send.
That is very weird I’ll change it back on my list.
50 in the day category…what?
Maybe the day category is the shift instead?
I’m using the divided voltage and the IPT60 hand torch that comes with the machine
Yeah it’s weird for sure.
I have no idea I was wondering why they just don’t use the physical day instead of the month and day but I think you have it right mine seems to be the only anomaly.
we had a previous thread with reference to a “24 day month” I guess we have to makeup the extra days somewhere why not have a thread with a 50 day month?
Weak attempt at humor…
I hope we got a few more serial numbers around your number so I can see what’s going on.
July 50th lol
