Did you try having FireControl generate a short line cut?
yes i tried manually firing the torch
How about FireControl generating a short line cut?
if manually firing the torch thru firecontrol doesn’t fire the torch then generating a cut line is useless. He needs to figure out why it’s not firing before anything else will work.
Ah, I miss read what he wrote. He should check that this relay functions electrically correctly (other than the click) using an ohmmeter.
Have you checked air supply to cutter?
Yes, Q23 or Q3 iirc from that article. I am going out of town so don’t have time to tear the machine apart atm. Will try when i get home.
I will say that it will be extremely disappointing if the control board nuked itself already. I’ve only used the machine a half dozen times. Hopefully Langmuir covers the parts if I have to replace the board.
Understand, it happens. Looks like that relay is on a sub-board. They might just send one of those. Could be something else though, check the continuity of the relay contacts when its powered.
Looks like in this photo, the torch control wires are orange and purple.
If your controller is similar, pull those quick connects apart and plug them back together. May you have some corrosion with these connections.
It was my stupidity. It works.
please share what the fix was, it might help others
I did in the other thread I created. Plasma cutters need air to fire the torch.
Great use of the Fireball square!
ack. Machine was working great until this evening. Tried to cut my new packout shelf design and it is kaput.
I tried to lower the PH and cut height by 0.01 and same… Yes I remembered the air this time.
I don’t have a new set of consumables. Only had the one inner cone part, not the nozzle thingamajig.
You have feed rate set at 0? Bump the plunge rate to 60 ipm or higher to.
.5 pierce delay? is that 1/4" material?
0.125, same stuff I have been cutting all the stuff above.
I changed some settings, created the code again. Going to try it this evening. I suspect it is consumables because nothing else has changed, other than the weather.
