This would be epic, Langmuir likely has the entire machine model already in some software, I wonder if they would allow you to use that or if they plan to build it in fusion themselves?
I plan to model most of the major components individually before I start assembling, then I’ll just put them all together with joints in fusion. Some will have to wait until after concrete is in though. But I may simplify some of it so it will save some time/frustration. I’ll just see how it goes.
@langmuir-mike Do you guys plan to release a machine model?
Something dumbed down would be amazing for machine builder for all of us! we don’t need the design but a model with just the 3 axis and spindle would make everyone’s life a ton easier!
If Langmuir would post simple .stl files of the main components we all could use them to make working machine simulations for the various CAM programs we use… hint hint @langmuir-daniel
We don’t need exact, specific dimensions or every component. Just analogs of the base/table, and primary moving structure.
Just uploaded the following to GrabCad, if anyone else has parts they’ve modeled please post links to them in the comments section on that post so I can update the machine to be more accurate as time goes on.
