I have multiple issues that I am in a mad rush to try and sort out. Here are the details of my issue concerning live voltage reading:
Running a Hypertherm 45 XP
45 amp consumables from Hypertherm dealer
75 deg. hand torch has been converted into a machine torch using many references in this forum.
I have been cutting parts with moderate success. The cut quality is decent, but I suspect the minor issues going on would have to do with my live voltage. It also looks like there is a slight bevel on my cuts, but that could also be an optical illusion, I suppose. I might be being overly critical at the moment because I want to produce parts that people would want to spend their money on.
I guess I need to start saving for a machine torch. I don’t have an extra $600 to fork out right now.
Until then, I still want to keep designing, cutting, and selling some of my work. Do you have a resource as far as wiring internally (or advice). I am new to a lot of the wiring and configuring of these units and what not. Am I damaging anything in any sort of way by cutting with this live voltage issue?
is it possible that your hypertherm is outputting 20:1 voltage isntead of the requried 50:1? The outputted voltage sure makes it seem like its outputting 20:1.
The system takes the voltage inputted to the VIM and multiplies it up by 50 which is what is displayed in the live voltage DRO in firecontrol. 243 volts would suggest that 4.86 volts are being supplied from the plasma cutter to the VIM. I’d check that with a multimeter.
I am not sure. All of this is a new ball game for me. From my understanding, the Hypertherm 45 XP’s factory setting is 50:1. If it is in fact 20:1, how do I go about changing that?
Well they shouldn’t be their. You should have 4 wires coming from the CPC plug to the Langmuir box. 2 are for the trigger and 2 a positive and a negative for the THC.
