Limit Switch Homing Kit for CrossFire and CrossFire PRO is COMING!
I installed my LS kit, and got everything working fine. I then ran into an issue that v1.3ls firmware fixed. (homing the system would result in the z axis hitting a hard stop and the motor would continue to try and move against itself. Not good)
Everything had been fine until today. I attempted to cut a piece and the torch does not attempt to go down and zero the z-axis. It fires the torch in air well above the piece, and then takes the z-axis against a hard stop upward and stays there while attempting to fire again. It isn’t until the second fire that it realizes that there is no THC and then throws an error.
Anyone else experiencing anything like this?
Is your ihs switch stuck open? Is this new codes? Have you tried previously cut codes? Could be a cam issue.
Two other topics you might look at are: Y axis loosing it’s Mind! (Soft Limits?)
and:
Windows 11 problems?
We have no confirmation whether these people fixed their issues but they might be related.
Switch is not stuck, not new code.
Everything is functional manually. Did some checks on the THC voltage and all is good.
