There isn’t a problem with using a desktop. There have been interference issues reported using a computer with the grounded plug. Easy fix is to use a ground adapter or break off your ground pin on your chord/power supply if you have one.
I think I remember ( and that is a long shot) that there was something one of the tech’s said about the length of some cables…and that the programs were calibrated to a certain length of cable…and that going too long might affect the operation of the systems…
I made my own laptop stand (as a first CFP practice project) that required a longer usb cord. I’m running a 10’ long cord. Bought a 4 pack of ferrite chokes and have 2 on each end. Zero issues so far.
Good read, I’m running a hynade plasma cutter since I’m using off brand and unknown compatibility I want to make sure I don’t introduce problems into my setup. Thank you.
It sure has the hallmarks of a high frequency machine which if it is you absolutely shouldn’t use it on your CNC machine.
But provide your model number and we could look it up more thoroughly, they make several different plasma cutters. I see some use blowback style consumables and some use high frequency style consumables.
After you have some run time on it please post your thoughts on the machine. I’ve been thinking about picking up their CUT80 machine as a dedicated cutter just for the CFP.
Somewhere langmuir states that their machines are designed for 40-50amp plasma cutters. I am unaware if going above that effects something. But it’s good for thought.
