This sounds like the error that is produced when the CutControl post is used instead of the FireControl post. Can you verify which post processor you have installed / selected when you select post processing?
From the above image, choose the Folder icon at the end of Post. (Red Circle) This will open the Post Library. From there choose the Import icon (Red Circle) and select the FireControl post processor you have previously downloaded.
After that, the FireControl post will be selectable in the Post Processing window.
Thank you so much, after adding it, it worked, i went through all the Langmuir videos and must of missed it. I think i need to go through some of them again.
So are you all set? It takes a month or two to start feeling comfortable with fusion. Don’t give up on fusion because you won’t outgrow it. When you start working in bodies and using sheet metal is when it all gets fun if you have bending capabilities.
Here is recently posted video on sheet metal in fusion.
