hey guys is this HF or BB???
Amico APC-70HF
@mechanic416 @TinWhisperer (AKA Manual-Man)
Its high frequency that is why the HF in the name.
Are you sure or just assuming because the HF in the name? I didnāt find anything that states it is, and even called the manufacturer before I bought it who said it wasnāt. But now iām having goofy issues with my table.
OKā¦Mechanic416 (george) answeredā¦and you saw itā¦George is a Plasma Guruā¦sellsā¦repairsā¦and knows his Plasmasā¦I think you have fried your electronicsā¦I would send Langmuir a support ticket indicating you might have fried your tableā¦they might be helpful and offer something quickly for you at a reasonable priceā¦
Yes I am sure! You are getting pilot arc and HF confused! Well the manufacturer layed to you!
Not only that, but my antivirus tool is flagging their url as an āuntrusted certificateā.
I searched for quite some time and it almost seems like itās a " lie of omission" .
They donāt seem theyāre very forthcoming with their manuals I wasnāt able to find one anywhere?
The only literature I could find to connect it to high frequency was if you search the p80 torch variant that machine comes with it is a high frequency torch.
I appreciate the help and research. I believe you are right and as far as publication goes, they arent lying, they are purposely omitting that fact. Their ātechā support how ever straight up lied.
You are right. I assumed HF and PA were different.
Off the list Langmuir provides, are there a couple you recommend? Like 1st 2nd and 3rd place?
Sorry, I really donāt recommend plasma cutters. The best thing is to ask the members on here what they use.
If you donāt want to spend Hypertherm money, Everlast 52/62i and Primeweld Cut60 are the most popular lower priced machines.
My local shop has Miller Spectrum 625bX-Treme models in stock. I know miller was a good name in welding growing up.
do a search on this forum for that model to see if others have gotten one to work with the table. Might even find wiring instructions.
#1ā¦top ratedā¦hypertherm unitsā¦
then just about anything on the approved Langmuir list of plasma cutters
https://www.langmuirsystems.com/plasma-cutters
I run an Everlast 62iā¦and love itā¦I could not afford the Hyperthermā¦
PrimeWeld Cut60
Interference generated by the power supplies of these cutters have been known to cause issues with CrossFire electronics. Owners of these models who wish to use their cutter with the CrossFire must take further steps to ensure proper grounding and resistance to EMI in their systems.
Use of these cutters is not supported by Langmuir Systems and is at your own risk.
the Primeweld is no longer supported due to interference issues. Its been put on the naughty list. I see lots of people on the forums using it just saying you need to make sure to use chokes and and ground everything properly. Sounds like playing with more fire ugh.
Primecut is getting better for CNC. @EmersonSC check this post out about some of the changes theyāve made.
Thereās no doubt though that the older machines have caused a lot of hassle for some people.
Talk about face customer service. I sent them a message via their website and got a response minutes later:
|### PrimeWeld.com Customer Service [email protected]|2:27 PM (3 minutes ago)||![]()
| ā | ā | ā |
|to me
We sell CUT60s for Langmuir customers daily without issues. We have done updates internally the last few months and again no issues
Gene
On Fri, Feb 25, 2022, at 02:25 PM, <@gmail.com](mailto:gmail.com)> wrote:
You received a new message from your online storeās contact form.
Email:
Phone:
Body: I am looking at the Cut60 plasma cutter, how ever apparently Langmuir Systems has dropped support for your machine as it causes too much interference with the electronics. Have you guys looked into these issues and made any changes to fix these issues? I am ready to pull the trigger but cant afford to replace the electronics on my CNC table again due to a plasma cutter frying them.
works fine if you follow precautions. As with all cutters, donāt have cables crossing or laying on top of each other, uncoil the work clamp cable, move the cutter as far away from the control box as possible. having it on the opposite side from the control box works fine.
the new updated cut60 works fine using the cnc port but you can always hook it up using raw voltage from inside the cutter.
Hey Emerson, you in Howell Michigan? You could stop by and check out my pro table with titanium 45 cutterā¦
