Amico APC-70HF...compatible....?
Is there anything within the cutter that needs to be change (dip switch, dongle, etc) to make the CNC port have the correct 50:1 output, or is it “plug & play” in those regards? I already found the posts that help with the wiring of the CNC plug/port so that wont be an issue.
Sent you a PM boss!
the pins on the cnc port are already 50:1. Pin 4 to red wire and pin 6 to black. that’s the most important part of hooking it up since those 2 are polarized. the torch on/off is not so wiring it won’t matter.
