Bracket V2…wraps 2 sides of rail…
<V3 g-code below!!!>
lol…when I get to building this, I’ll probably have my welder out and just weld it…![]()
Ok time to stop…waaaayyy to much time on this…
Finished edges, made it a little bigger…screws not included…lol
LS Crossfire Pro Shelf Bracket v3.nc (4.3 KB)
Here’s the DFX if you want to play around in Sheetcam/Fusion…
CF Pro Shelf Bracket V3.dxf (5.3 KB)
Edit: This part is available on Fileshare as well for anyone interested.
I won’t be at table for a few days to mess with this, but would be cool if someone cut this and shared a pic! Have a good one!
Now you’re just showing off!
I watched that same Fusion360 table build video yesterday. Now I just need to stop procrastinating and try it.
Yeah - it was the DiResta shop table one. It connected a few dots for me and was a big help.
This table is a hoss…its .25" wall 3" tube. Not messing around!
I’d flip this over - rather have the weight of the rails & shelf (and whatever’s on it) bearing down on the screws holding it into the CF legs. I think there’d be less of a chance of shearing the screw shanks or even pulling them from the CF leg. Of course rivnuts would be a good add to this build as well.
I agree! Of course, now I’m going to have to learn how to do stress analysis in F360 for the weight of my plasma (15lbs) + 13 gallons of water table solution (108.49 lbs). This might get a little over engineered! It never ends! I like the rivnut idea - saw a post about that a while back…I should probably just weld the tubes to legs - that won’t go anywhere, but I wanted to leave the original CF pro frame as untouched as possible. There are probably 100 better ways to do this…thanks for following along!
Edit - oh - sorry - that last pic was from the bottom…looking down…I re-read your comment, and I realized I took the pic upside down.
This view shows top of pic towards water table.
Just purchased mine from Amazon delivered this past Sunday. Will make a nice clean job for many projects.
REXBETI 14" Rivet Nut Tool,… https://www.amazon.com/dp/B07MVXN7LK?ref=ppx_pop_mob_ap_share
Like I needed another way to separate me from my money.
Thanks for link!
I would love a review on that tool, alot better looking than the $80 1 size pita one I use now
I have the same one with the pumping rod instead. I think it was an extra $1. Even so, the thing is cheaper than the grinding, welding, painting effort needed when you don’t want to use a thru-bolt.
Living in the north east, working on rusted POS vehicles I loath rivnuts. Every time I encounter one it spins. So I can’t bring myself to buy the tool… no matter how useful ![]()
I think…
LOL! Yeah, we hear the commitment!
Been working on a new caster / leveling foot design using my new Fusion 360 skills. I’m a F360 convert at this point - really enjoying using it now that I know how to get around…and the CAM is great as well. Took some time to get there, but much more proficient now…
Not sure if this design even makes any sense - I’ve got a few other ideas floating around in my head, but thought I’d put this out there to see if it generates any ideas. 1/4" plate. Tube that CF leg sits in is 2 1/2" .25" wall tubing welded to base plate. Gussets welded to base plate. Tapped for caster and leveling screw.
My goal is to roll it out of storage into working position, put a level on the x and y axis and walk around with my impact driver / socket and level the feet out. When done, I’ll retract the feet and roll it back to storage. Might move to a plate mount caster vs stem as well.
Did you create the caster model?
No - the caster and the foot are from McMaster-Carr - STEP file import. Everything above the caster, I modeled.
You have really got a hold on Fusion… WOW!
What if you moved the wheels out to the flange, and the leveling screws directly under the legs. Would be structurally stronger when in use and loaded.![]()
Those Lars videos on YT are great - really got me off the ground with F360.
Good point, but I can’t get my impact driver on the nut. I’d have to use a wrench, but I’ll have to noodle that idea some more…interesting…thanks for the post!![]()
Thanks! Good to know!
An interesting piece of software I ran across in Fusion360 help forums.
http://www.nc-corrector.inf.ua/index_EN.htm
NC Corrector is an editor for g-code. It has a visualizer and the ability to “play” the g-code and watch the operations.
There are lots of editors out there - I use Notepad++ frequently. The reason I mention NC Corrector is that it has a feature I’ve been looking for - g-code to DFX conversion. It allows you to export gcode as a DFX. I found one or two programs that sort of do it, but this one seems to work pretty well. Most of the time you’ll have the design you generated the gcode from, but in the cases where you don’t - this will let you create the design from the g-code. I’ve had a few cases of this, and it’s useful to me.
Another interesting feature that I like is you can click in the visualizer and it will jump to the line of code that generates that line or arc. I can see where that’s useful in a large complex gcode file especially if you are trying to track down a cut issue.
(I wish you could do that in Firecontrol and click run from here)…
Another tool for the toolbelt…
Scored my new pump from the Hazzard Fart today - on sale!
Thanks for the tip on the coupon! ![]()
They are one sale thru 6/30/20.
Also got in a magnetic chuck from Amazon. It took about 2 weeks for some reason, but it’s here. Saw this in use on a fabricator’s YT channel (42fab???) and it’s a gamechanger. Magnetically hold small parts / letters when grinding / finishing. Mine is a 5x10 but I don’t see it on site anymore. 6x12 would be closest. Extra set of hands.
https://www.amazon.com/gp/product/B07ZJ86G6W/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
And some AVE stickers for a laugh…
