I have been trying to locate this file for far too long.
I saw it yesterday while surfing on my phone and thought, psh, I can find it on the laptop later and download that file… eh, senior moment…
someone posted a quick file to run. It would essentially zero, and set cut height at .06, I believe. Then, pause. no fire… so a newbie old guy could then go measure where the torch is actually sitting in relation to the steel.
Can someone point me to where that was, is, will forever be?
Mrs Bigdaddy got a new Nintendo Switch 2 yesterday, so I am watching Zelda.
Oh boy. Remember, “A happy wife = a happy life,” Jimmy. When she thinks I’m not watching, she shouts Langmuir.
Yeah, that was WAY quick!! Thanks! That helped a lot! Was set far too high even after using the cheesy measure sticks. Just ran a pretty large file and it looks like everything cut nicely. I’ll have to raise my travel rate back up now and see how it does.
PS, I don’t mind the hostile takeover of my thread… I still got what I needed FAR quicker than me finding it on my own.
Ok, quick question.
I run this file, set my nozzle height. I see in fire control when it sets that physical height, Firecontrol shows cut height at zero.
So, that being said, I physically set my torch height at .06 when the file ran. Loaded a new file, and for giggles, set firecontrol cut height to zero.
Is that right? or completely out of lines.
I have z axis and thc and what’s the other one ihs… ?
setting it physically and then setting firecontrol to height 0 seemed to give me a decent cut.
I also adjusted my air. I had the regulator set to 75, but while it was sitting. I just ran “gas test” so it was on and flowing, and set the regulator at 75 during the flow test.
I’m so close to ending the waste of material! lol… next step… big boy plasma cutter.
After you run the program. You physically check what Fusion is setting the torch height. If it is set for .06 and you measure .10, reduce the Fusion set point to .04. You may also want to set the backash setting to zero from .02.
I am not a SheetCam guy, but the same process applies.
I am not sure if I understand you. You will not be “setting firecontrol cut height to anything.” The gcode will tell FireControl what you have baked into the gcode. Don’t mess with those settings in FireControl.
The file we shared tells FireControl to set the torch height to 0.06 inches. We are only having you measure the outcome of that test to see how everything is communicating that endpoint. If it is not what you expected (namely a torch height of 0.06 inches) you would go back to SheetCAM and adjust your cut height accordingly for your cut files. This then becomes your new target for the cut height and you will need to remember that number (or perhaps SheetCAM will remember the value you last used).
Let’s say you measured an actual torch position of 0.09 inches when you had it set at 0.06. You need to get rid of the addition 0.03 inches so you would tell SheetCAM that your cut height you desire is 0.03 inches.
You can verify if it is actually doing things correctly by interrupting a cut with the space bar and measuring. The reason that is not always accurate is that you are now mixing other factors that might move the torch, in this case THC. If THC is adjusting for the voltage, it might be moving away from this programmed cut height.
Correct. If SheetCam or Fusion’s cut height is set at .06, then the torch should be .06 from the tip to the metal sheet. If it’s higher, like .10, then adjust Fusion or SheetCam to .04. Get it?
After you change the post-processor settings to make the difference, test the code file again. It should be 06.
