Didn’t know how the posts in between worked; I’m not here much and hate this format ![]()
Mainly why I don’t come here much.
well practice makes perfect!
Hmmm…been a mod to two other vehicle forums, and have been on some forums dating back to 2009 ![]()
I need to stop joining forums!
2001 was the year that I first joined one.
Probably soon after fora appeared, having moved from Newsgroups…
And soon after people started using this weird networking technology called WeeFee or something…
Just highlight the text you’re replying to and hit the Quote option that shows up.
You’re a young’un
My favorite rat ones were Compuserv ones in the early 80s when we needed to tie up the phone and listen to the squeal to connect ![]()
looks clean! cool stuff!
Made some wheat today. I’m making a mount for a new weather station.
https://www.instagram.com/p/C-Ri2QGM92J/
@langmuir-zachary @langmuir-alex This needs to be somewhere on the ‘wall’ of Langmuir photos!
Edit: For those of you who have not found it, this is where those photos might show up:
Mounting base, chickens, bees, wheat heads and leaves all cut on my Crossfire Pro
Maybe without that particular intro phrase…
good point, goes without saying
I agree! @ChelanJim
More 1-in thick plate shenanigans.
I had to remove a cylinder on a motor grader tool carrier and needed to make a bracket to keep the tool carrier up in the air.
Came right out with that one section being the only dross. Aside from some little chunks here and there .
I was going to try to just bore the holes that I needed on my mill, but I screwed up and used an old Cutting Edge not thinking that that’s hardened steel. Now I have to sharpen an annular cutter.
I did drop the dog bone back into the plate where it came out of and torched out the two holes that I needed then just clean them up with a boring head on my mill.
100 amps at 10 inches per minute. End-to-end was 37 and 1/2 in long and three and a quarter inches wide in the center
I also had to duplicate this piece twice
I had pictures of the bits and pieces of 3/4 and 1-in plate, but don’t know where they went. Here’s the finished product
I cut this a while back, thanks @ChelanJim for the help in getting the file cleaned up as well as sharing his knowledge. Just finished it up today.
That is awesome! And I know it took a lot of effort to paint, so congratulations on a job well done.
Thanks Bret.
