Been dealing with a torch shutdown after initial pierce and not continuing cutting the design. Using Sheet Cam for this file as initial setup seems to be easier. I went through all recommendations from help pop up and still no file cut except initial pierce hole…
If your pierce delay is set too short it may fire on the first pierce or any restart pierces because Firecontrol adds a little bit of time to these. The second Pierce will be what you set it for in the g code which if it is too short it will not fire.
Yes, if the torch isn’t hitting the material before the ihs switch is triggered then it doesn’t know how low/high you are off the material to start off at.
The THC doesn’t set the torch height. The IHS system does that. The THC just uses voltage readings to try to keep the Torch at the height set during the IHS loop.
Lift up on the Z axis and see if the IHS light turns green in the Firecontrol screen.
The IHS should be grayed out until you lift the Z axis carriage, which opens the IHS switch. If the light is Green ask the time, the switch is open or a wire is unhooked or broken in the IHS wiring. A common issue seems to be the brass ring connector coming loose from the switch.
Seems like I was searching yesterday and seen someone had posted it. I will look for it. I actually checked mine yesterday. I cut a small circle paused mid cut. Had set for .06 but it measured .075
The tack @nicaDd was on is that the torch is mounted too high to touch the material to trip the IHS switch. That’s an easy thing to check with a small GCode snippet.
I think Langmuir should add the pic I posted earlier on where to place the torch holder in relation to the z-axis position… it places the torch travel pretty much in the middle of travel in the pos/neg directions with enough room to minor adjustments in either directions.
Agreed. Its a very common problem and the instruction don’t provide any guidance or explanation of how the IHS system works and why the torch mount needs to be mounted where it does.
