Torch not staying on
Hello All:
I am a VERY frustrated Engineering Teacher with a new CrossFire Pro with z control. I have it all set up. I had my students design projects, send them to me as a .dxf and then convert them in SheetCAM to .tap. I can see them in FireControl. I thought I had all the adjustments set. However, when I run “start” the torch fires for a second, makes a burn hole, and shuts off without moving.
+clamp attached, check
air pressure, check
pierce delay .5, check
voltage on the THC seems correct, check
played with the override on the pierce delay, check
What am I missing?
Thanks
what cutter are you running?
I’d start with a .8 sec pierce delay and adjust from there.
what are your other toolset settings?
Welcome
The most important things to mention are - plasma cutter, how it’s wired (divided or raw), material thickness (this changes the recommended pierce delay), and what error you are receiving (if any).
Have you successfully cut anything before? Or is this the very first time?
Can we see a picture of your setup in its entirety?
RazorWeld 45, no other tools.
Do I need to manually set the torch heigh using the “jog” feature before hand?
What is the torch height. I read it should be .16". Is that correct?
Thank you for the speedy reply
Stressed out teacher :slight_smile:
I’ve never cut anything before on it. I am trying to cut 16 gauge sheet metal.
I don’t own a Razorweld, but my two other plasma cutters state .06" cut height.
You should refer to the included owner’s manual for your plasma cutter.
As for setting it, you would do that in CAM. I don’t know how to use Sheetcam so I can’t point to where/how you would do this but I can say if you have a programmed height for say .06", you should do a test cut then pause mid cut, and measure the physical distance with feeler gauges from work material to the tip of your torch.
If there is a deviation from programmed to physical, make the adjustment on the programmed side, re-test, measure and verify. It’s best to do this at least twice to ensure IHS isn’t a factor in giving you an incorrect cut height.
Hi everyone, I’m a student helping out with this plasma cutter process and we had many issues prior to this one we worked through but this one got us stuck.
We checked the connection, it’s fine.
We checked if everything was plugged in, it is.
We checked the program to make sure we had no issues, there weren’t any.
The cutter just doesn’t seem to be working. We can dry run the program fine. but if we try to use the cutter on the program it will turn on at the start point but turn off after making a hole in the sheet. Can’t find the issue. Please let us know if anything is missing or if you have suggestions on what we should check out next.
Thanks For Helping,
Tyler.
Test Cut.nc (1.0 KB)
Try this.
what’s the PSI set to on the internal reg inside the cutter? The RW45 should be set to at least 75-80 PSI for it to fire consistently.
other sheetcam settings should be, Pierce height .15, plunge rate At least 75 ipm, cut height .06.
there’s also a settings that states “reverse cut direction” that should be checked so it’ll cut the insides CCW and the perimeter CW.
Still the same. I have it set as you recommended. It cuts for a second and stops and then lowers.
PUT water or something in that table.
Also, some people may cut items out with the work clamp on a slat or the table…but I’ve always recommended people to place it on the material itself.
I’m sure any one of us could help, but in a fast-paced environment like this I think you would benefit from a video call or something to quickly run through troubleshooting steps (and ensure everything is correct).
I’m available later this afternoon (say, 2.5 hours from now).
That would be AMAZING! I would greatly appreciate it. I can be available whenever via phone or Zoom. THANK YOU!
I have Zoom (paid version, unlimited time) so I’d be happy to help. Will be in the garage later to help once the wife gets home from work.
It’s 1244 here now, so basically 1515 or so.
Check these wires, if you would:
that looks like the THC input cable coming from the cutter. it’s just snaked underneath the VIM box.
I think you are right.
The symptom that is occurring is that the torch gets a signal to fire. That will turn the torch on. But the THC is not sensing voltage so it then aborts the cut. Perhaps it is as simple as the wire coming from the VIM is not fully connected at both connections (VIM and/or Enclosure) or a connector is damaged or a wire broken.
(Note: It could also be a connection issue with that wire that you and I assume is coming from the cutter’s divided voltage.)
