New to this, so patience please. Ran the simulation, project is not cutting the small rectangular shape inside the two small circles, but shows cutting direction (red arrows) when selecting. Everything else cuts fine. Profile 2 is for the holes only, Profile 3 is everything else.
Post your F3D and I can show you exactly what went wrong with your tools path.
normally fusion “discards” any contours that the total of the “linking constraints” will not fit into. you can see on the left in the browser bar the yellow triangle with exclamation mark on profile alerting you to the paths being discarded
“linking constraints” are the lead in, lead out, pierce clearance, kerf width, etc all the option in the “linking” tab of the 2d profile menu .
I took a look and It looks like you have two origins. I tried to delete your set ups and it wont let me for some reason.
I’m not that good with fusion, I would start a new drawing, if I was in a hurry.
I’m sure someone will fix it for you if you cant wait.
I created new f3d file for you so you can see how I would do the cut path. I have different plasma cutter and setup. I don’t select each line or hole. Let me know if you have more questions.
I cant thank you enough! Perfect. I ended up creating two profiles, 1 to cut the holes at different parameters, and 1 for all of the simple cuts. Modified, posted, everything seems ok. Cutting tomorrow…stay tuned.
Just ran it. No problems. So just for my information, can you give me the exact steps you had to take to correct it? I am just trying to pinpoint my errors. Thanks again.
In summary: your original set-up was not finding any object to use so the toolpaths were void to start with. If I were to guess, you were making changes to try to get the toolpaths to work out and in the process deleted some body or sketch elements. You will get it figured out…it takes time. Don’t despair.
