@TnT Did you get your TD working with the THC?
No I haven’t yet. Have you had any luck?
While hunting around I did find this plasmaspider post from 2018 where they’re trying to figure out the same thing.
Thank you I will look it over.
Yes I’ve got mine working but not with raw voltage. See my post above. It explains how I did it with CNC card installed and the Hypertherm plug n play cable Langmuir sells. It works like a charm!
I just got my 60i automation card and cord installed and was able to do my first cuts on my PRO with the IHS but the THC test is not working. No voltage. I have the pins connected per your previous post. My question is, do I need to do something with the plate contact pins? Am I missing something obvious? Any help is appreciated.
The only mod I did was to route the divided voltage thru the OK to Move relay. Did you verify the Automation Interface card is set to 50:1 output? It should be by default but it’s possible the dip switch is not set right.
Got it working! Bad connection on the divided voltage wire! Thank you!
Thanks for the info, just to confirm. If wired correctly, there should be continuity between pins 12 and 14 while the torch is on?
Correct. And Welcome to the forum!
Thanks for the welcome. 12 & 14 are not continuous during cutting and so I am not getting a voltage output through pins 14 & 6. Makes me think my “Ok to move” relay is bad. Do you have any suggestions and if not I am wondering how you got in contact with Thermal Dynamics.
Gene is the senior tech. Ana was also very knowledgeable and helpful too.
Technical Support
ESAB/Victor Technologies
1-800-426-1888
2800 Airport Rd
Denton, TX 76207
Fantastic. Much appreciated!
I have a service manual(PDF) for the 60i but it’s too big to upload to here. ![]()
Already got it. I’m not particularly well versed in electronic schematics so I can’t make all that much sense of it. I checked the resistance across 12 & 14. During cutting operation my meter reads No Load. Interestingly though it has a non-specific resistance in the kohm range while the machine is not cutting.
Are you re-routing the divided voltage thru the OK to Move circuit?
I moved pin 5 to pin 12 then put a jumper from pin 14 back to pin 5.
Yes, I am. DIV negative from the thermal dynamics automation card to pin 12 and pin 14 to the negative input for the VIM.
