THC Installation Step by Step
Could it be something in the post-processor configuration?
It’s been a while and lots of other crap went through this old brain since. Will look through my notes tonight.
i haven’t table wet
i work three axis x,y,z with mach3 and a thc controller
i want to make a plasma cutter but i have problem with z axis znd thc150 controller
i thing that maybe i make a mistake to the configurastion pins or the licence of mach3
i don’t know i try a alot of days with this
Ciric…
this forum might not be the place you want to be looking for help.
this forum is for people who want to own a Crossfire table…or people already have one…
there is not a lot of people trying to build tables from scratch here.
i’m in the begining of my expiriance in cnc plasma
i have a router but i work to make a plasma
i see this post and i work on this
Dicky, I’m about to start the same project on my Crossfire. Did you finalize your wiring? How did everything work out?
is anyone still active on this? im trying to help a friend convert a g540 to the Mach3 usb controller. i got X,Y,Z to work but having issues with making a relay work to fire the plasma. i believe it to be a setting issue as i have no clue what im doing when it comes to the software. i been an repair tech for over 30 years so the wiring was easy for me. any help would be greatly appreciated!!
The torch relay is supposed to fire with an M3 command and turn off with an M5 command in the GCode. This is controlled in the general config tab, and the general purpose pin maps. I don’t have a system handy, but I’ll see if I can dig up a config file. In the meantime, have you loaded the CrossFire config profile?
The configuration is in Config->Ports and Pins->Spindle setup. Set M3 (CW) to Output Number 1. Then, in Pins and Ports, I believe you map output 1 to Port 3, Pin 4, Active high.
2 posts were split to a new topic: THC showing voltage when not cutting
