Specifications to make a replacement Output Voltage Cable (SOLVED)
Would any of you have recreated the cable for the two conductor Output Voltage? Goes from the “DIV OUTPUT” to the electronics enclosure.
I moved and cannot locate my cable.
I am looking for the pinout for the BNC type connector to the barrel connector and if anyone knows the correct size/description or part number for the connectors I would appreciate it.
Thanks for your help,
Jim
That is the 2.1mm x 5.5mm Male barrel connector, typical with surveillance cameras.
Like this:
If you search for “barrel” connector you will find it but there are a few with very similar sizes so make sure it is the 2.1mm x 5.5mm.
https://a.co/d/ao8lvGc
Thanks for that info. Any idea what the other connector is called? It looks sort of like an M8 metric circular connectors but I am hoping someone knows for sure. Also, looking for the pinout, which part of the barrel connector goes to which pin on the other end.
Oh!!! Totally sorry. Don’t know that but someone will know. That was talked about on another topic but it has been about a year ago.
Here is where it was discussed but no one called the connector by name:
I did figure out the connection of the wire to what pin and how it relates to the barrel connection at the VIM box:
Thanks, that helps!
Now I just need the part number or proper description for that two pin connector that is in your hand.
Jim
That is a 2 pin aviation connector. They come in a few diameters, so measure the port to get the correct one.
It’s probably a GX12, but I’m not sure.
Thanks David. I figured you would know but I didn’t want to put you on the spot…
Based on the measurement of that black plastic being 8.82mm, I would say this is it:
Hxchen 2 Pin Metal Male Female Panel Connector 12mm GX12-2P Silver Aviation Plug - (2 Sets) Amazon.com
Thank you so much! Part is ordered, I’ll be back in business by Saturday. I appreciate the assistance!
GX 12-2 pin is correct. Amazon Hxchen 2 Pin Metal Male Female Panel Connector 12mm GX12-2P Silver Aviation Plug - (2 Sets) Amazon.com
BigDaddy, you were my other hope!
SOLVED in less than 24 hours. What a team!
