Please list the shield part-number
Should be tecmo 51924
Hey guys, What is the pressure output on my plasma cutter, Mine is dropping to 40 psi while the torch is doing a cut. I checked my compressor pressure and it’s about 170 to 150. Is the pressure set that low from the factory on the rasorweld cut 45
You will need to take the cover off and adjust the air regulator so you are getting at least 65 psi with the air flowing. If it won’t hold the air at that psi then you will need to get a new regulator.
You should only have 120 psi to the plasma cutter max.
Hello,
I thought it would be best to upgrade the torch, This one I just bought,
Can you guys let m know if this one takes these tips,
Yes. Answered on this other thread you posted:
Do you have a part number of the one i need to use my good man?
No. That would be @mechanic416
georgesplasmacuttershop.com.
He is very honest, trustworthy and has been a respected member of this forum for years. He will steer you the right way. I am not sure if the website link works.
Edit: the link works and it has a link to his ebay page.
Its a CNC shield and they have them on the Langmuir store
This link will take you there.
