Hello All,
I have the razorweld cut 45 on my crossfire pro wtih Z assembly. I am having problems with cut height and, how my setting are setup in fusion 360. When I run a test cut on the machine it seem like IHC works.
touch’s the metal then retracts, Seems like the cut high stays about 4.4 mm from the metal.
Can anyone here give me a screen shot of your cutting library tool settings for your Razorweld cut 45.
I am stuck. I am going to include my g-code as well for review solar_project-100.nc (1.3 KB) Solar_part 4 v4.f3d (129.7 KB)
Welcome to the forum. I have not confirmed any of the settings on these charts. I have Hypertherm. But these are pdf files that have been circulated hundreds of times on this forum:
Thank you, Don that was really helpful, I am stuck on creating the correct size cutting tool,
Do you think you could guide a little on creating a tool for this setup?Don Help
Don has probably already told you but it is not setting a different “tool nozzle diameter” to capture contours but to modify the lead-in/lead-outs to fit into the contours. And since you did not have a tool path in your f3d I was not able to see your settings so this is just a quick example.
If the contour is not being selected, try to reduce the lead-in. You can also pick “Preferred lead-in point” of each contour to try to get Fusion360 involved with all contours.
Notice how increasing the Lead-in Radius, Fusion360 drops the “3”, feeling that there is not enough room for the lead-in:
I have Hypertherm so have different consumables. Need to see your electrode and this don’t look good.
Someone with your plasma cutter will be more helpful.
Need to be all about what you have for moisture control now.
You should have a mechanical shield. Some consumables are unshielded. Not sure if yours are unshielded. I wouldn’t cut with that shield you are doubling your cut height. Very hard on your consumables. Cut quality will suffer
