Razorweld 45 50:1 pins
So my brand new XR came with a razorweld 45 but only one of the necessary connection cables. I have the torch on/off cable, but the one that goes from the unit to the THC module is missing. I can use the one that came with it and attach using one of the male end connectors that came with the 45, but I need to know which wire goes where. There’s a red and black wire and the connector has a 1 & 2 label where the wires connect. Any help??
If it is okay with you, I will close this topic since it is duplicated here:
Let me know on your other topic if you want both open.
