Program- Pierce, no cut but straight line generator works fine
Nice work!
You will get better results if you clamp the work lead to the material being cut instead of the slats.
I use a small cutoff discs to add texture to many of my projects. The more time you spend the better the outcome. Look at a picture of how the hair falls on a bear. 14ga steel you can make some really nice deep marks.
Maybe try it out on small piece of 14ga and see if you like it.
Thanks. Still learning all the small details. I have had so many “Failures”…
In no particular order…
  1. forgot to turn on crossfire computer
  2. forgot to turn on plasma
  3. forgot to flip the breaker on the geneorator,
  4. forgot to plug in air hose
  5. forgot to open main valve on air tank
  6. forgot the laptop power cord
  7. forgot the UBS I have my gcode fills on
  8. forgot to ground anything
  9. and many other hiccups…
Sounds interesting. Im not much of an artist but I like learning
Just to save you some time, just list what you did remember :thinking: :rofl:
Make sure you check for any moisture in bottom of air compressor.
Made me laugh out loud! Thanks!!
@Scoopburt
Just put that list on a sticky note on your computer screen like the rest of us who have forgotten all those things at one point or another. :wink: :rofl:
Im assuming you are talking about draining the compressor? If not please elaborate. Thanks
I installed a ball valve drain which I open at the end of each day. (minimal) and I have a 2 stage seperating between the tank at the plasma. It auto drains when I turn off the supply from the tank.
I have read a good portion of the forums… still much to learn. Looking for consumables now. Only have one tip left. Lots of back and forth regarding which tonise as well as supply shortages… Im guessing due to extra busy shops cutting x mas items
When I was typing this list I had to stop… the HICCUPS are entertaining… Im of an age and mental state I pound my fits then laugh because I dont have time nor enough patience to be anger any longer than that.
Yep I did it a little differnet laminated a check sheet and have a dry erase marker
