Yes high temp, you can buy them on Amazon
I found some 36 X 48…
Yep those would work perfect. It’s underwater and steam won’t be an issue.
I ordered one this evening. I’m thinking of using part of it to make a gasket for the water table since it is a little big for the bottom of the water tray. User reviews of the mat have mentioned they used the product for making gaskets.
Could you take some more of this setup
Sorry meant to ask if you could take some more photos of that setup my bad
Added 3/4" drains to my table. It’s just a drain, no fill. I figured it’s easy enough to just pour it back in. After I drain it whatevers left over I just wet vac it along with all the sludge that’s in there. The wet vac works out pretty good.
Which setup are you looking for?
yours and Israeltop
thank you sorry for the long response
What drains did you use? Look like they sit pretty flush
I made them. I cut out a washer from 14 gauge and welded it to black steel pipe after cutting 1/4" of the threads off. I used plumbers putty under the lip and tightend it up.
Here’s some video links if anyone is interested in my final setup. https://www.facebook.com/groups/921396168061150/permalink/1324153824452047/
Link notvworkibg for me…
Me neither. @custommetalmke any chance you can put the videos on youtube for us non facebook types. Thanks.
OK I will put it on YouTube. Yeah probably won’t work if you aren’t on Facebook.
Here are those links. Sorry still new to using YouTube. https://youtu.be/55Vq8ixZgI4
https://youtu.be/bdECqTjaUAM
nice work on the table. the sump looks amazing.
I am going to go with that silicone funnel for sure…not only does it look cool…but I bet it works well.
I can hardly wait to do my complete set-up with shelf and drains.
question…what do you figure is the water volume?
So you are draining from only one side, is there much left in the other side?
Thanks.
Looks good!
My guess is no more than 20 gallons. The funnel with keep the rails cleaner for sure!
