Pro pierces then stops cutting - Program paused
I’ve got a new CrossFire pro and was looking at making some first cuts today. Running with a HyperTherm Powermax 85 cutter, FireControl 20.6, and SheetCam with the FireControl V1.6 post processor.
The program runs great when in dry run, but not when actually cutting. The torch pierces the workpiece (all teh way through) and then the program pauses. It shows as paused on FireControl. If I resume the project, the torch goes through the motions, but the cutter is not triggered. At the next pierce, it does the exact same thing. I’ve ranged my pierce time from 0.5-3seconds without having any effect.
The first bit of the Gcode is listed below. The torch stops cutting as soon as the G1 (Gut Height) command is given. I get no errors listed on teh screen, it just pauses the program.
My guess is it has something to do with IHS or my Z axis zero? Thoughts?
(v1.6-sc)
G90 G94
G17
G20 (Units: Inches)
H0
G0 X5.885 Y3.5945
G92 Z0.
G38.2 Z-5.0 F100.0
G38.4 Z0.5 F20.0
G92 Z0.0
G0 Z0.02 (IHS Backlash)
G92 Z0.0
G0 Z0.18 (Pierce Height)
M3
G4 P3
G1 Z0.059 F3.937 (Cut Height)
H1
G2 X5.885 Y3.8208 I0.1131 J0.1131 F45.0
G2 X6.562 Y4.1012 I0.6771 J-0.6771
G2 X7.5195 Y3.1437 I0.0 J-0.9575
G2 X6.562 Y2.1862 I-0.9575 J0.0
G2 X5.6045 Y3.1437 I0.0 J0.9575
G2 X5.885 Y3.8208 I0.9575 J0.0
G2 X6.1112 Y3.8208 I0.1131 J-0.1131
H0
M5
G0 Z1.0
G0 X6.5614 Y5.1425
Do you have the THC chip installed but not connected in FireControl? Can you connect to it and have it toggled off in the THC Control module within FireControl (underneath the Overrides)?
Yes, that would be where the issue is. I’ve actually not been able to get the THC to connect, which is why I was trying to run without it. I was unable to find a way to override this in FireControl. It just says “No Connections.” But, I did remove the card and showed it worked without the THC installed.
Any ideas why FireControl shows “No Connections” for the Height Control? I followed the THC install guide and I have both a green LED on teh main board and a red LED on the THC board. I’m using the Raw inputs on the VIM box and verified that I have correct continuity between the clamp and the torch. I have a cable from the PV output to the THC input on the controller.
Likely a missing driver. I think this thread will be of use:
I’m having similar issues, I’m also running a Hypertherm 85 and same version of Firecontrol and SheetCam. Dry runs works great. When actually trying to cut a part pauses at each step and does not cut or sometimes will cut every other feature and other times will cut out a full part but most times will not cut.
pierce delay…increase that to start…
Thanks! Your support team was super helpful on this!
not even a small thanks to us…boooohooooo…:cry::cry::cry:
