Hey all,
I thought I would post for other new purchasers and in case some of you with experience have additional or other recommendations. I have just received my Crossfire Pro, but have been preparing for and buying and installing all of the other accoutrements and necessities and niceties to go along with it, mostly based on community information and suggestions.
It just seemed like it might be hard for someone looking into it to glean what all is (or could be) involved in it, aside from the initial purchase of the “machine”. Specifically I had the goal of trying to “do it right” or not cheap out too much ![]()
Firstly, I tried to deal with the air supply. So I upgraded to a more appropriate compressor, an Ingersoll Rand SS5L rated at 18SCFM@90psi, figuring I would not be left wanting for air. Was a good deal at $1500 for what it is.
Since my shop is small, I pretty much had to build a compressor shed off the side of it. Of course that turned into a new run of 240V, when copper is at near $2 an LF, and 2x4’s at $8 per
Then the moisture issue. Refrigerated dryers (especially high heat ones) are expensive, so I opted for a DIY copper after cooler based on numerous peoples past experience. Of course, copper pipe is at an all time high of $40+ per stick. still working/deciding on between compressor/tank cooling options.
Then the runs of 240v 10/2 romex and hardware for plasma cutter and re-routing existing stuff.
Then some filter, regulator, desiccant dryer hardware…
and finally leveling casters, because my shop is too small for permanently mounted ANYTHING
I already have a plasma cutter (Everlast PowerPLasma 50S, but may be upgrading)
In short, aside from just purchasing the unit, there was a lot of stuff to figure out, 80% from the great forums here, with all the OTHER stuff that goes into it (or can go into it, depending on where you want to end up).
I ended up reorganizing 1/2 my shop to accommodate the equipment, wiring, air plumbing, etc. (not a bad thing).
So I just thought I would share where I am at.
