To make your life easy, mix well with 75 oz of water and put in a gallon jug. Then, every time you need to add ‘solution’ to your system, mix one ounce (2 TBS), with each one gallon of water.
Adding 4 gallons? Easy, add 1/2 cup of solution to your 4 gallons.
Tags: Sodium Nitrite Formula Anti corrosion
