No live voltage
I have a pro table that was using an Everlast 50S with raw voltage in the VIM box.
I just upgraded to a Hypertherm 45XP with the Langmuir plug n play cable. I am NOT getting any reading on live voltage now so it stops running immediately because live voltage is lost with the THC. What could it be? What have I done wrong?
My voltage is also zero when I fire the torch on the material manually. I am not getting any voltage reading.
I’m an idiot. I got it. I am so dumb.
I did not move the RAW output to DIV output!!! That has to be it right. Dammit.
Yes that would definitely cause the issue. Did that fix it? Thanks!
Yes. I feel like an idiot. Stumped me for about 30 minutes. All of your support everywhere linked back to “you have to have it wired wrong” and as I looked at it again it clicked “you changed input. What about output?”
I vote to leave this up so if anyone else is as dumb as I am.
ahma follow this for that ‘slap on the forehead’ moment for myself :wink:
There are no dumb questions! Live and learn!
Yes, live and learn…example don’t open a beer at 9pm, take a sip and expect it to be good at 7am :stuck_out_tongue_closed_eyes:
where did you move it at im stumnped
If you are having THC voltage issues I highly recommend going through our guide here: LS-THC Arc Voltage Troubleshooting Guide
Hey Everyone, Thought I would put it up on the forum see if anyone can help out. I am also seeing 0 live volts (See Pic) I can toggle control the THC unit manually. I have even gone as far back as to re-open the electrical enclosure to ensure the THC module is installed correctly. I am running a hypertherm 45Xp with machine torch with the plug and play cable ( Also Triple checked x 100 ) that cable is correct, ( Maybe still wrong ??)
If anyone could please help out, I am yet to make a cut on my X fire pro so i am as green as they come.!
crossfire%20software|690x310
did you get this fixed? having same problem
What problem are you having? The live voltage is supposed to be zero unless the torch is firing.
yes, it was a faulty unit, Langmuir replaced some parts for me. I cant remember what. The table is working very well now. Sorry I cant be more help.
