Thank you for that. Coming from you Mr brownFox one of the top gurus of plasma.
4:57 am I guess you don’t sleep either like TinWhisper ![]()
Mountain time is 0300. So, not quite as bad. I’m off work from my day job at midnight and I have a decompression period. ![]()
Guess I’m not the only one who’s losing sleep waiting for my MR1. I’m on the forum more often than I should be. Can’t wait to see the epoxy fly!
You are correct. The measurement is .250 below machine outer lip. Thats prior to machining the base plate.
random question, but do you know the distance from the bottom of the machine to the floor? also do you have any pics of the bottom of the machine?
Send me a drawing of what measurements you need. I gone home already. I’ll send them to you about 5 am est.
You got it. I’ll send you pictures of the bottom also.
How much is the weight of the table without an additional items on it BD.
Don’t know yet? Spec’s says 750 - 900 lbs. I think its closer to 1000 with the concrete.
Shipping weight was 854 lbs
Less pallet 100 lbs = 754 lbs
6 - 80 lbs concrete = 480 lbs
Less vises and accessories 100 lbs
Total 1136 lbs
Did you email Langmuir for the measurements of the legs to build your stand? I had been waiting on it to arrive before I built the stand as I didn’t see actual leg measurements anywhere. Since my machine arrives on Saturday, I guess it doesn’t really matter at this point, lol, but I thought I’d get started on building a pallet-jack-compatible base tomorrow night.
Base leg measurements at the bottom are.
38 inches across the front. 39 inches front to the rear. All measurements are outside corner to corner at the bottom.
Awesome, thx!!
Cool idea. With running the wire i figure mines getting put in one spot and left there.
Can I ask where you sourced the pallet Jack?
Made it out of 2×4 11ga tube an 1/4 plate on top. Sourced adjustable feet from McMaster Carr.
Nice work! Thanks for taking the time to reply.
Epoxy day tomorrow ?
Tuesday. Waiting on extra epoxy from Langmuir.
Better to have to much than not enough.
They shipped it out Friday and it should be here Tuesday morning.
