Just remember to undo the hack when you try the new post processor or weāre going to be very confused ![]()
That sounds great guys⦠Very interested to see how this goes⦠The other thing that was getting me was entering ms type number for pierce delay when setting up a tool in sheetcam⦠Then run the simulator in sheetcam and sit there and wait for 400 actual seconds⦠Wasnāt making much sense to me.
Iām probably ok with the hack for now but, the simulation would still be wonky⦠Right?
Right. But you can slide the speed bar all the way to the right to get some of the time back ![]()
Right on!! Thanks James!
i just tried your āhackā and it seemed to work. I set time unit to seconds, restarted sheetcam, set the pierce delay in my tool to 300 s and post processed a simple file and when i opened the TAP file, the GCode line shows G04 P300
Okay hereās the modified post for Sheetcam. Download it and delete the .dxf extension so itās called āMach3 plasma milliseconds.scpostā and copy it to your Program Files (x86) > Sheetcam TNG > Posts directory.
Then in Sheetcam, click on Options, Machine, Post Processor tab and in the middle click the down arrow and find the new Mach3 millisecond post processor. (ignore the blackout in the screen snip - itās where I store my tap files and itās got some network info that Iād rather keep obscured)
EDIT: Keep your Sheetcam using seconds for the pierce delay (in the tool setup screen) and the new post processor will convert to milliseconds. This one will come out as āG04 P500ā which is 1/2 second or 500 milliseconds. Use ms in Sheetcam (like ā500msā to be 1/2s) and Mach3 will be happy with the tap file produced.
The post processor is attached as a fake dxf (since thatās what the forum allows) - you just need to strip off the .dxf so itās a .scpost filetype.
Mach3 plasma milliseconds.scpost.dxf (4.1 KB)
Ok iāll try it out. thanks!!
ok i imported it and set everything per your instructions and the tap file displays the G04 output to milliseconds, ie⦠P300 for example.
then, for shits and giggles, I went back to application options and set the TIME units to ms then edit my tools pierce delay to 300 ms instead of .30 and post processed using your modified post and it still output using milliseconds.
without actually running a live cut, i would say it works. I would keep the time units to MS in sheetcam to match mach3 and cut out the confusion.
Actually that makes sense the way I coded the post. Sheetcam sends a value to the post in seconds regardless of how you specify the units in your tool definition. My version of the post knows that and always outputs in ms.
So if you say ā300msā Sheetcam sends .3 to the post. If you say ā.3sā it sends .3 to the post. Iām converting that to ms in the post (the default doesnāt - it just leaves .3 which is what Mach3 fails on if youāre doing seconds in Mach and if you had G04 milliseconds checked in Mach that would be treated as .3ms which is hugely wrong).
Iāll be using the new post to cut a couple of things for someone this weekend and will make sure itās not doing anything bad. Then Iāll update this (probably start a new thread so it can be found more easily) with pictures & arrows and skip the āuse seconds in Sheetcamā as you noted.
(Iāve updated the post above as well in case someone stumbles across this in the future.)
confused! lol. - but thatās easy for me. I need to do this conversion as Iām using sheet cam, mach3 and a finicky Everlast 60s
on a serious note, which set of instructions do I start to follow above? Iām gonna give this a run shortly.
If youāre going to use my updated post processor then you need to have Mach3 set to milliseconds. Then in Sheetcam specify your times as #ms in your torch definition. The tap file will work correctly for Mach3.
Found it, Thank you James.
James, I installed and tried your modification and it does what you say it does. Which post script did you start with for your mod? The post that yours is creating still has some z commands in it and I canāt tell if this is adding time to the pierce delay or just idle time.
I then applied your mod to the (Post processor: Mach3 plasma no X.scpost) and there is none of the Z axis commands in the gcode this time and it runs faster, When I get time to cut then I will compare both and see if the extra time is before or after the torch has fired.
Thank you for providing this.
I thought I did the āno zā but I modded a couple as I was trying things out so I may have done both. I would have thought Iād upload both though if I were providing options ![]()
James, I thank you for your modded post that you provided, I now have another tool in my toolbox thanks to you.
Safe cutting.
that might be true. Iāve used/tested his mod a few times and the pierce delays seem to run a bit long even when i change the values. thought is was just me. Iāll mod the original NO Z post and see if that changes anything.
Also, i donāt remember the Z axis values changing in mach3 when you start the Gcode when i was post processing in Fusion but they do when post processing from Sheetcam. I wonder if thatās fixed when using the No Z post also.
I believe it will and I just ran my line test file and did a post of James and then put his mod into the no z post and there was a noticeable difference and with my new screen with the firing timer you can see the difference and if you watch the display part of the screen then you will notice the arrow in the right actually moving down and this is happening after the torch fires. I like what James has done because it has made my life easier, for now I will use his mod in the no Z and later when I have the Z axis then I will use the one of his that I found.
The first screenshot is James original post mod and it takes 36 seconds with a total firing time of 26 seconds
The second sxreenshot is James mod put into the no Z post and it runs 29 seconds with a total firing time of 29 seconds.
Thank you James for this mod, he still gets all of the credit.
cool, i will have to try it out tonite.
Iām interested in what your cutting action settings look like - and how you defined your torch. I may have different settings that make the Z not execute even with the Z compatible post.
Yes sir, just let me know what you want to look at and Iāll get it for you. I already left the shop for tonight but Iāll be back tomorrow. I can upload my whole Mach3 file to dropbox if you want to look at that?
Just let me know, Iām just glad that you made the mod, without that I would still be doing it the hard way.
Are you talking about the timer that I have on my screen?
Thank you
