So your last post that says “Solved” is not correct?
no it was not i was hopeful that it was but not successful
Did you make any progress?
i have my biggest accomplishment was gettig torch to fire
Well Roger (@Willyrog), Don’t give up on us…or on Langmuir support.
If you have not done so, start another topic and describe, in as much detail as you can muster, what your setup consists of: plasma cutter, consumables and where purchased, air supply and drying techniques employed, software used, gcode of a file that is messing up, photos of your table/torch/consumables.
Someone will either have an idea that helps or might trigger your imagination to help problem solve the situation.
i have one started and i have watched every you tube video i can find
Is it the “Having trouble with THC test”? The last post there was 2 months ago.
Those ‘older’ topics tend to fall off the radar. If it were me, I would make another post on that same topic to bring it back to the forefront of the forum. Tell people that you are lost and don’t know where to turn. Make sure that you have answered all the previous questions that people have asked and supply information they needed.
thats not my post my original post was torch wont fire langmuir has sent me a new mother board .relay switch a new torch fire plug and cable i have gone through all the trouble shooting guides i have researched other forums i have years of welding and using plasma cutter so i know what to trouble shoot with plasma it has been very exhausting
This post right?
Last post was in March.
that was my very first one i have another one with pictures and results from trouble shooting Akel has been very helpful
I know this sounds painful, but I would start a new post and list what has been done and tested. The problem can be fixed its just a matter of how much time you want to invest.
I have been in your shoes before and only you know, whether or not you want to pursue this again.
im pretty sure im dome i cant imagine starting over just wanted to say thanks to all that tried tp help
