Iam using the titanium cut 45 i can fire torch manually and when i short plug going into contrl box the machine fires but will not fire from program before i installed THC it was firing when i did test but get nothing now 2024-03-29T06:00:00Z
EDIT: tomws: I moved your post INSIDE the post and modified the topic so it’s easier for others to help.
Welcome to the forum.
recheck your torch fire wire connections inside plasma cutter, bad connection I soldered mine? Did you switch Torch fire plug and THC plug at ports on controller by accident?
Email Langmuir for a new board. Open up the control box and check all the connections. It may have loose wire or is unplugged from the board. Follow the torch connection on the control box back to the board.
It’s a rare occurrence that there is a bad board. Most of these guys don’t follow directions and hook things up incorrectly. Take that with a grain of salt.
not sure if it is an issue that only iam finding but directions for installation are not easy to find and i completely understand issues with not hooking them up properly
Locate the torch firing cable that was provided with your machine and connect the blade connectors to the T-Tap connectors.
It does not matter which blade connector gets plugged into which T-tap connector. The polarity and wire coloring is not important.
Im not familiar with your plasma cutter. If it has a CNC port, the torch pins are NORMALLY pins 1 and 2.
That is not always true.
I didn’t see it mentioned, so can you confirm that you have the torch on/off wire plugged into the torch on/off port on the electronics enclosure.
It may sound like a silly question, but a large percentage of people with this problem have plugged it into the VIM box instead of the electronics enclosure.
