I cut preview is not displaying during cut operations
I have the cross fire XR and everything is working correctly and making projects, but the progress display that I see on other tutorials is not showing. Mine is just showing a percentage of job progress. I have downloaded the video driver but it did not make a difference even after a system restart.
In the top right corner you will see the search function. do a search for “visualizer” I think you will find some help there
Welcome to the forum.
Are you using the computer/touch screen that comes with the XR table? If so, it could be as simple as the setting on the top/left:
If you are using a different computer then this might be more appropriate:
