Let’s make some cool Halloween stuff for the fileshare!
Here is first posting…
Halloween Pumpkins | FireShare | Langmuir Systems
That’s a very cool wall!
New pumpkin sign. I added one of my small brackets in the design. Holes on brackets are for tack welds not bolting since total length is around 2" long bent.
https://www.langmuirsystems.com/fireshare/halloween-pumpkin-trick-or-treat-bat
Here is a Jack O lantern for this design potluck .
I have not cut this yet so beware. Once this pattern is proven I’ll post it to FireShare.
It is 14 round and 10 high plus stem.
There are relief slots so someone should be able to fold it by hand.
Here is a DXF of the pattern
PUMPKIN FLATS.dxf (124.9 KB)
And here is a 3D model
Please post if you make one.
Only a couple days till Halloween.
I saw this knick knack on AliExpress I’m going to try to remake it in fusion 360 to be cut out on the plasma cutter.
I’ll start a live streaming about half an hour I’ll post a link on this post when I get down to the computer.
Here’s a link to the product on AliExpress that I’m going to use for inspiration.
I think I’ll modify it so a tea light becomes the light source.
Live Stream Channels
3D MODEL link . test model are a neat way to view 3D elements. try below and use the continue in browser option.
HOLLOWEEN LIGHT BOX.dxf (507.6 KB)
Make at your own risk this design has not been tested
Fun project! I can see a few ways to do this one. I would start with an existing can and tack in the items or even use a grinder wheel cut openings in can and insert them in spacing you want them. I’m excited to see the end result. Tin is alway impressive!
I posted this one on Fireshare a month ago. It was to go with the trees Don P or someone else posted.
Cut one out today. I’m going to make a few alterations to the design.
Here is a picture of Halloween lightbox v2 . Made a few revisions.
See, showing off like this is doing nothing to improve US-Canada relations! ![]()
That is awesome man. Add some glass sides, water, and a few goldfish and it will really pop!
