Fix for XR Drains
I upload a project to Makerworld it has all the files and information
3.5 in sink basket swaging die set TinWhisperer by fourthstatecnc - MakerWorld
Bot Die 3.5 sink basket swaging tin.step (22.4 KB)
Top Die 3.5 sink basket swaging tin.step (23.2 KB)
washers X2 quarter steel 3.5 sink basket swaging tin.dxf (2.9 KB)
3.5 sink basket swaging dies tinwhisperer v3.f3z (578.1 KB)
Description from maker world post
Wanting a more robust drainage system in my Langmuir XR plasma cutter water table I made a swaging die for a 3.5" kitchen sink basket.
I wanted some nice big drains that sat well below flush. I installed X4 in my XR and i am sure the die could do many more. The metal thickness is about 20ga mild steel.
The dies were designed in Fusion, exported as a step file to Bambu Studio and Printed with 100% infill ABS on a X1C. The backing plates for also design in Fusion and cut on the XR from 1/4 mild steel.
Here is a link to the Langmuir XR for those who don’t know about their Plasma tables.
https://www.langmuirsystems.com/xr
You will also need
4 Qty ½" x 3" bolts
8 Qty Washer ½" hole 1 ¾" diameter
2 Qty Plasma Cut Washers from ¼" Steel ( DXF file included )
locate hole center
hole saw a 3.5" hole and deburr
assemble swaging die stack into the center of the hole
start to evenly tighten bolts in a star pattern a little at a time till fully engaged
evenly loosen the bolts in a star pattern a little at a time till fully disengaged
clean apply plumbers putty and install strainer basket
Repeat
I used the Moen PRO FIX M8632 Strainer Basket Assembly.
I may try this with a 3 3/8" hole saw if available
For more information you can check you some of the discuss of the forum.
Thanks Tin for another cool design! Just downloaded it. Cheers.
You are a boss! thank you so much for sharing and the detailed description on how to do the task.
Morning Tin, awesome idea. Could I please get the 3D print file? I’m gonna have a buddy of mine print these. My XR shows up Tuesday so trying to get the mods done prior to full setup like I did for my Pro.
Thanks again.
Thanks
The file are linked above but a complete file and run down is available here.
https://makerworld.com/en/models/488523-3-5-in-sink-basket-swaging-die-set-tinwhisperer?from=search#profileId-401524
Good Luck with your XR
Thank you! Appreciate all your help and knowledge. I review a lot of your material.
Thx for sharing the 3d print files for the 3.5” drain dimple die set. I 3D printed them on my bambu lab h2d yesterday and they came out perfect. The one thing I’m confused about is what are the two quarter inch washers for? Where do they go in the stack as I cannot tell in the pictures, how they are used?
You’re welcome I hope it works out well for you.
The two quarter inch thick plasma cut “washers” are for evenly distributing the load over the plastic. They go directly above and below the plastic dies.
And @joejoesmojo32 Welcome to The forum.
