Faults on New Machine (SOLVED drag shield removed)
Hi I am brand new to CNC and CAD in all aspects. I have loosely been doing research on the topics for a few years now as I have always wanted to get my hands on a Plasma table as that seems to be the logical step for dipping a toe into the automation world.
I’m running a 52i Everlast torch on a freshly built CrossFire Pro with THC. I am also running a massive air compressor that has a proper air dry system.
I am getting intermittent results on my initial projects. I wasn’t sure that my wire splicing and routing was going to work right off the bat but somehow everything seems to be firing well enough to run for a few minutes.
Anyways, I had two last minute jobs before I left for the Baja 500. I patterned 20 pieces 2" x 6" x .250" for job 1 and a 12" x 12" square with 4 holes .50" x .50" for job 2.
The machine was running flawless but after about 2 minutes I recieved a “Loss of Voltage” error.
Tried to retry the cut. Bonk. Again bonk. Skipped over to fresh material and the machine ran fine again. But after a bit I ran into the same issue.
I also noticed that my machine was dropping to 23 amps at the beginning of every cut, but there was no pattern, it was different almost every time. Had to use the grinder on quite a few to free them from the sheet.
I also tripped the 30amp breaker on my panel once. ( Its a new shop and I’m learning ).
The other CAD issue I’m dealing with is my piercing seems to be for too long of a period and I can’t solve it. My holes have a noticeable ear attached to them.
I’m wondering if my panel cannot keep up with the demand of the torch, my stock consumables are not correct, or if my programming is the issue.
Any and all suggestions are welcomed. I am down in Ensenada racing the Baja 500 so I won’t be back to my shop until next Monday, but I have plenty of downtime during the week to do my homework and banter back and forth with you guys.
Thanks in advance.
It would be helpful to be able to look at your cut file, but you probably can’t send that right now
30 amps is really the bare minimum that you can get away with for the 52i. 50 amps would be a much safer circuit.
What are you using for CAM? Fusion or Sheetcam?
Everlast 52i requires a minimum of 40 amp circuit to run @240 volts.
A 50 amp circuit would be ideal. Make sure you have the wire to the panel box thats can handle 50 amps. At least awg 6
Again awg 4 would be my choice.
Unit may not run correct if you are getting a large voltage drop on too small of wire.
The 30 amp breaker tripping is a sure sign of a problem. Send us some pictures of your wiring setup from your panel to the plug. Also the plasma cutter comes with a 50 amp plug. Are you using it or did you change it to a 30?
For you info. The 52i has a 100% duty cycle @ 40 amp or less setting. Running your table above that will require you to consider smaller cuts. Tripping the machine on duty cycle will shut it down and alarm on the plasma control panel. Not to mention ruin a lot of hard work and metal😜
Also if the breaker trips mid cut you have no post flow to cool off the torch after cutting.
Not to mention that when the plasma cutter trips on duty cycle, the plasma arc stops. This is your loss of voltage alarm on Firecontrol. If it is tripping on duty cycle the plasma cutter will show fault E01
The breaker tripped one time out of many many attempts.
The plasma came with a nema 6-50 style plug that matched the existing receptacles.
I am no electrician, and have a novice level understanding of needs or necessities in that field, although I do have some friends in the trade. I had one of them at my shop helping me wire up the compressor and he mentioned we could upgrade the panel if needed. I assume he put too much faith in my understanding and didnt take a glance at the specifications on my plasma.
I am using Fusion 360 for drawings. Thinking about it, I should start another thread in the software sub forum before I take this thread into another topic / direction.
I own a Miller Generator / Welder as part of my mobile setup. I will try to power the machine from there in between now and the panel being upgraded to see if that will help with the fault showing up. That has a 50amp breaker slapped in there.
Thank you for your patience. I’m eager to learn and become the grumpy guy yelling at the new guys one day.
By the way, I’m 30 and just starting out with my welding / fab business. Live in a small town in Southern California called Somis. Love beer, tools, and anything out in the dirt. Cheers.
Good luck in Baja… I like beer too… :grin:
Since you don’t know the “why” or “where for” of how that particular receptacle got put there, you might need to investigate further to make sure that the wire is actually suitable for whatever breaker you use.
This chart is for copper wire:
As quoted by my current, favorite wordsmith on this site @GaltsGarage: "We’ll see how this holds up, it’s definitely probably most likely not code. "
So I made it through another project on “limp mode”. I’ve got my electrician showing up Monday to assess and conquer.
He also installed a VFD I had for my lathe and mill. Every time I close the door on the sub-panel enclosure it cuts power so he has to fix that as well.
Side note. If you’ve ever wanted to go for an adventure before you’re dead, Baja California is awaiting.
Beautiful! Keep us posted on your progress.
I have tun both the 52i and the 62i…runnin with the 62i now…
things to know that I have learned after having Everlast units for 5 years…
  • dry air…dry dry air…people often say they have a dry system…but often they do not…here is a pocture of my drying system which is followed by a 1 quarts beaded desiccant dryer and a motorguard filter…went from 500 pierces to over 1500 and over 2 hours cut time per consumable
  • next is the post flow…run posgt flow for 30 seconds at all times…the heads can overheat and warp easily. buy a spare toch head just in case you warp one out…I always have one.
  • everyone is right…your breaker and power may be a real cause of your issues…
  • do not use off shore consumables…use the right ones from the supplier…
  • here is a chart for consumable tips and amps to go by…pretty accurate
    Consumables chart? - #3 by defiancewelding
  • the follwoinb comment I do not agree with…that is my tag line!!!..ahahahahah…
  • welcome to the world of plasma and the frustrations that come with it.
I’ve upgraded the system to 50amp and yet I run into the same fault. Low voltage blah blah. I’m going to have to look at how I hobo rigged the Langmuir to the everlast.
The frustrating part is that it will work fine for a while, when I get into the 2 minute mark of torch time is when it will spontaneously fault, and when I try and restart on half cooked material it doesn’t register properly.
My thoughts are
A. Slight warp in material throws off ignition due to differential in distance from torch. (Even though I paid for THC)
B. Temperature sensor somewhere is tripping due to overload. (Even though per literature I’m well within tolerance)
Either way Im pretty disappointed in my experience so far. I’ve paid the cash, I’ve put in the effort, and Im putting in the extra credit.
Nothing good comes easy and you get what you pay for. Irritated with Everlast and their CNC port that doesn’t work with this machine, or maybe im irritated with Langmuir that their machinery doesn’t support their voltage so and so.
Either way im not a software engineer, nor am I in the field of pulling rabbits out of my ass. Calling them has been a fruitless nightmare and I wish I would have spent the extra few thousand bucks for a turnkey machine where I can make money instead of scratching my ass like a Simpsons character.
There have been folks on here with somewhat similar stories and realized they had a voltage drop fault due to competing appliances “kicking on” and robbing amperage from their garage.
So, no possible relation to compressor, home or garage AC, clothes dryer, etc? How many amps feeding you garage?
There is a huge difference between a " low voltage" error on the plasma cutter and a " voltage lost" error in Firecontrol.
The first is an indicator that you have a power supply issue to the plasma cutter.
The second indicates that the Torch failed to fire or did not transfer from pilot arc to cutting arc.
Which one is it?
Duty cycle? What are you cutting ? What is the alarm on the everlast? E02 ?
I am super jello that you are able to race trucks in Baja. I have always loved racing, but it just hasn’t worked for me since we had kids.
Hi, still having some difficulties.
Not getting regular faults anymore, just having a hard time with the machine not running at full amperage.
Periodically the machine decides it doesn’t want to switch from its starting amperage of 23A. I am not sure why the machine starts every cut at 23A, but it does. Most of the time it will engage high gear and click up to my 45A setting, sometimes it takes a blink, other times up to 2 seconds. Worst is right now as I right this it just will not go above 23A no matter what I set the machine to.
Is there somewhere in the CAM process that is making the machine start at this low amperage? When I use the machine manually it just starts blowing holes at my desired amperage.
Thank you in advance for your patience, I am still learning one run of parts at a time.
I would guess you need to check your cut and pierce height. If you are using THC, the system is measuring in the first 0.25 inches to decide what your voltage should be. If the torch is too close to the metal, it will draw more amperage and thus will decide to rise. If it rises too much, then it senses that it needs to drop.
IHS (Initial height sensor/setting) may be sticking or the torch is not able to go low enough to trigger the plate touch and then just “assumes.”
What do your cuts look like? Dross, bevel?
Stop the cut by pressing the space bar, this will stop the torch and FireControl progressing with the program and leave the torch in the same position. Measure with feeler gauge.
The 23 amp reading your seeing is the pilot arc. If its not transferring to the cutting arc it is not sensing the work clamp/positive (also referred to as the ground). Always make sure your work clamp is on good clean metal. The metal being cut not on the table or slats.
