Here is the web address:
https://cutzilla.weeblysite.com/
You will have to contact him and let him know that you would like to purchase one and he will send you the information needed to purchase one. Hope this helps! I purchased mine the same time I purchased my (batch 1) pre-order Pro table and I’m still putting it together in between work breaks.
Did you get it for 12V or are you going to try & pull 24V from the Crossfire control box?
jamesdhatch
I’m not really sure at this time. It’s been a while since I last looked at it because I’m still trying to put my table together.
i ran separate power supply at 5volts mine is working … have to use the torch fire . with this set up you need to engrave first, then align where you want it cut … kind of a pain … but it works… i will say you want to make sure you have an oiler in the air line or it will lock up … thats what i did to the first one …
Thanks. I’ll take another look at what he’s got.
