So, yeah, I know I should have measured before but… The specs say a cutting area of 48.25" x 33.3". However, I have a piece of 48" on the table now and from hard stop, (you know, " klunk whirr" to hard stop, I measure 46.5" x 33.125".
Now, obviously, I still love my table but wtf? I gotta go redraw o WHOLE bunch of stuff and I’m going to end up wasting a lot of 1/4 inch plate, not to mention that my cuts will no longer fit on a single 4x8.
Are you measuring with a measuring tape or reported values from the system - If everything assembled and aligned properly you should have darn close to the spec.
After hitting the stops while dry running a file, I whipped out the tape.
Danny Downs, (who, apparently has no life outside of supporting boneheads like me!), had the answer. I switched the X axis bearing mount with the Y when I built it. (Of course the TABLE cut everything I asked if to despite my screw up) Kudos to the LS team!
Interesting. I was thinking of asking others if they are able to rip a whole sheet, because I keep having to cut the last .5 inch with my grinder.
I have yet to load a sheet that is 48”. They have all been over , some up to 1/2”. I have a fence on the left side to align the sheets square to the y axis with the ability to edge start if needed. I’ll straight cut across the x and if any is left I can usually cut it with a pair of side cutters.
Yep, if it’s 48", I can do it. 48-1/2"? Cutoff wheel time, (side cutters would have taxed my old hands tonight, cutting 1/4")
can you show us your fence setup? I’m wanting to build a feed table so I can just keep sliding the 4x8 sheets into the plasma table as needed…
1” square tube mounted with 3/8 all thread, double nutted as needed. Tramed in to .001 with a dial indicator riding on the carriage along the y axis. Use a second piece of 1” as a spacer along the fence when bringing the sheet in then remove before cutting. Someone else had already done this on the forum so I can’t take all the credit. Can’t think of his name at the moment.
Don’t know why the pics loaded sideways. Hope you get the idea.
May have been me? Here is the thread with some more pictures:
Yep , it was your post. Thanks for responding, I want to give credit where credit is due.
I know this might sound stupid.i believe I am having the same problem how could you tell the difference between the 2 Bering mounts??
The two "Y axis mounts are right at 2-1/4 inches, the single X is about 1-13/16. Sorry, no precision measuring device available right now
