Cut path duplication fusion 360
i have made a 2d sketch made a cut profile and g code already
i now want to make 16 of the same part is there a way to make a linear patter that will also input the cut path from original part the the other 16
The last bit confused me.
What is it about the pattern function in Firecontrol that doesn’t work for you?
If you are in Fusion you can pattern tool paths in the cam environment. I made a video about it a few years ago but apparently it’s only on loom and I never transferred it over to my YouTube channel.
Once you do have a tool path you like in fusion. there is a pattern Function.
SheetCAM also has a similar mechanism .one of the SheetCAM gurus could point you in the right direction if you’re using she can’t
And like @Kwikfab Stated FireControl itself also has that function.
i believe i figured out how to do what i intended with this particular cut but its not really user friendly if you are doing multiple separate sketches on same sheet
